02-07-2021, 07:11 PM | #1 |
Drives: 16’ Camaro 1SS Join Date: Jul 2020
Oil/air separator removal help
Can anyone on here chime in and help me out on how to remove the oil air separator? Accidentally broke a stem right at the base. If anybody could help out that would be great! Haha
02-07-2021, 07:22 PM | #2 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I did that once on my 2016. Just stick a tube part ways down and get JB weld putty. Works like a charm.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
02-07-2021, 07:56 PM | #3 |
02-07-2021, 08:13 PM | #4 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
I used jb quick over a year ago solid as a rock
02-07-2021, 09:54 PM | #5 |
Would be nice if someone made a black anodized billet replacement for these. Way to easy to knock off a nipple and then the water pump has to come off to replace this cheap plastic tank.
02-07-2021, 11:27 PM | #6 |
02-07-2021, 11:28 PM | #7 |
That would be cool. I hope the tubing and JB weld works a charm for me as well
02-08-2021, 04:43 PM | #8 |
I used this type of JB weld. You can even use the piece that broke off and form a weld around the crack. It’s pretty straight forward, just give it 24 hours to set for a good strong hold.
02-08-2021, 08:13 PM | #9 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
I broke mine too the left one, i used permtex black plastic weld. Its been holding fine over a year and change.
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
02-08-2021, 11:47 PM | #10 |
Awesome thank you. I knocked it out this morning and it worked out well. I appreciate your input!
