04-19-2024, 06:28 AM | #1 |
Drives: 2017 2SS Convertible Join Date: Mar 2021
A8 TCM module removal - is car still driveable?
Hello,
I have a situation where I want to remove a TCM from SS with A8 in order to unlock it and be able to minimize the shudder (by changing lock-up speed delta) however in the meantime I need to leave the car in at the shop to fix some body work issues. Question can a car without TCM move around the parking lot at mechanic's (in an emergency or service mode)? I have info that the older transmissions were able to work without TCM just allowing you using 3rd gear and reverse. Is that the case for A8? I will appreciate a feedback. @Admins please remove the same post I made in General forum, or move it here deleting this one. BR, Jarek
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) |
04-19-2024, 07:24 AM | #2 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
no
GM Gen V Calibrator
