Old 04-29-2024, 11:59 PM   #1
Kamero6
Drives: 6th Gen LT1
LT6 Intake in LT1 Engine. Since the Mustang got 2 TB, we should too.
Hey,
I was just wondering about the LT6 intake in a camaro. I think it has more volume than our intakes so it would be fun to see what it does.
Has anyone tried to fit an LT6 Corvette intake in an LT1/2 engine?
[IMG][/IMG]
Ports don't match in shape and size, but I wonder if the centerlines do? In that case an adapter plate might work.
Thoughts?
Kamero6 is offline   Reply With Quote
Old 04-30-2024, 07:08 AM   #2
The only interesting Mustang engine has only one throttle body
(The article itself at the link is junk, but the engine photo is the best I've found.)
Old 04-30-2024, 08:06 AM   #3
CJZ-SS1LE
Drives: 2022 camaro SS 1LE
I dont know if it would work but if it did dam that would be fun and look good!!
2022 Camaro SS 1LE, 427 Darton sleeved, Diamond pistons, Callies ultra rods, Callies crank, King bearings, ARP throughout, Cometic gaskets, large bore ported CID heada, Cam motion custom cam, C7R chain, Schumann oil pump, BTR pushrods, Johnson lifters, MSD intake, Katech 103mm tb, Rotofab cai, Kooks 1 7/8 headers, 3 in mandrel custom exhaust. Hp T93 TCM.
CJZ-SS1LE is offline   Reply With Quote
Old 04-30-2024, 10:50 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe these are completely different intake port designs, let along every other part of the engines.
'20 ZL1 Black "Fury"
Old 05-02-2024, 11:06 PM   #5
Kamero6
Drives: 6th Gen LT1
Ports are different shape but the most important part is centerline. I read somewhere that they match.
Fabricating an aluminum adaptor plate and if needed some JB weld
I think the runners are longer in the LT6 intake, also volume.
I can get a cheap spare lt1 intake but those LT6 are expensive to play around and compare
