Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-21-2024, 07:29 PM   #1
Ckmerc
Drives: 2013 zl1
Upgrade Throttle body or not?
So I am going to do my second set of mod upgrades [2013 zl1) and my buddy mentioned adding Throttle body upgrade (Nick Williams 102 is what my mech has in stock).
Question is…will I notice that much of a difference for the cost? ($700 installed)
Background
Once this next round is done…I will have had done the following
- ported blower, upgraded pulleys, E85 upgrade, new injectors, cam, long run headers, new clutch, 2 tunes…should end up at approx 800rwhp
Thanks for advice in advance!
Ckmerc is offline   Reply With Quote
Old 03-21-2024, 08:15 PM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
At that power level you should notice a difference. I picked up something like 40 whp going from a ported 90 to a 103 for my Whipple.
Sent from my Pixel 8 Pro using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 03-22-2024, 11:59 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hey Larry, lol, I just saw this and was going to mention you and what you did gain from the 102 I sold you!! Awesome brother!!
1JEWLDSSRS is offline   Reply With Quote
Old 03-23-2024, 05:53 PM   #4
Ckmerc
Drives: 2013 zl1
Whoa. Ya. That is noticeable…. Thanks!
