06-11-2023, 07:51 PM | #1 |
Drives: '23 RRT 2SS 1LE M6, '15 SIM 1LS M6 Join Date: Oct 2015
LT1 engine oil capacity- need 10.5+ qts?!?
2023 2SS 1LE… changed oil and filter twice now, first at 500 miles then today at 1600 miles. Each time it has taken a bit over 10.5quarts to get oil registering mid “okay” region on dipstick.
Drained oil with front of car on 10” high RaceRamps. Oil brought up to operating temp right before change. Let drain until very slow drip. Then refill with 9.5quarts (including refill of filter) and pull off ramps to have car sit level. Have to add additional quart+ to get oil showing in the middle of the dipstick range. Never had a vehicle ever want markedly more oil than specified capacity (in this case, 10qts) to get normal dipstick reading in all my years. Also checked cold after letting oil all drain back down, no real difference in level. Thoughts? Dipstick length off? Normal?
2015 SIM 1LS M6 - fun DD commute car 2023 RRT 2SS 1LE M6 w/PDR - FUN!! |
06-11-2023, 08:30 PM | #2 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
10 quarts or slightly less on all my oil changes to end up between the hash marks
06-11-2023, 08:53 PM | #3 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
10 quarts always gets me to the top of the hash marks, usually a little over.
06-11-2023, 09:29 PM | #4 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Race ramps might affect it. I need more than 10 qts and I also have the car at an angle to drain. ZL1 but not sure there is a difference in the oil pan.
06-11-2023, 09:36 PM | #5 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Mine also required 10.7 quarts to get to top of the hash marks (10.0 was only 1/3 way up the hash marks). The car was in my garage when filling and I let it sit overnight before taking any readings, so there's no way I had a mis-reading.
I wonder if some of this has to do with how long you let it drain the old oil. I've let it sit there until it stopped dripping out of the pan. Perhaps others stop at an earlier point. |
06-12-2023, 01:19 AM | #6 |
2020 Shadow Gray 2SS
Always changed my oil (5-6 times now) on a QuickJack (i.e very level, the very reason I bought the QuickJack) and the car has been level, let it drain for 45-60 minutes (minimum) and the change then filter and plug it back up and fill it with 9.5 quarts, lower it and almost every time end up putting the last 1/2 quart in to bring it to the top of the hash marks... 10 quarts out, 10 quarts in...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
06-12-2023, 07:42 PM | #7 |
Hmm, seems like I might not be the only one seeing this per wakespeak and Camrolina.
Next oil change I will aim to make a good measurement of the amount of oil that comes out to better understand. With hot oil and letting drain for 30min-ish feels like I am getting most anything that's gonna come out. Drip is down to a drop every few seconds at that point. Found this curious as every other vehicle I've owned always had the "can't get every last drop out" so the fill amount to normal on dipstick was always a bit less than specified capacity.
06-12-2023, 09:02 PM | #8 |
Interesting how mixed the results are, even 1LE-ness doesn't seem to make an obvious difference.
I always put 10.0 quarts in (I don't even order an extra bottle, which I probably should) and get a subsequent reading nearly at the top of hashed section of the dipstick.
06-13-2023, 12:30 AM | #9 |
Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
My 1LE is in the club "10 quarts put me at 1/3", so I usually put 10 quarts and then add 0.3-0.5 quarts more.
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle. |
06-13-2023, 09:18 AM | #10 |
Welcome to the club jollymon and KillrillWA! Our moto is "10 quarts is not the end, but rather the end of the beginning."
06-13-2023, 12:04 PM | #11 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
10 qts right in the middle or the hash marks, good to go!
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
06-20-2023, 10:02 PM | #12 |
Drives: '23 LT1 & '16 GMC Canyon Join Date: Feb 2023
First oil change @ 1500 miles. Put in10 qts and is at top mark on dipstick. Installed the Votex magnetic drain plug. Installed the ZL1 Addon lift pads while up on the Raceramps.
06-21-2023, 10:10 PM | #13 |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
I think you are on to something with your thoughts of the dip stick length.
I think the correct thing to do is to put 10 quarts in and check the dipstick reading. That is your full mark.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
07-09-2023, 05:15 PM | #14 |
376 cubic inches of fun
My experience has always been that the spec oil volume is exactly at the upper limit of the dipstick. You just need to fully warm up the oil and then wait for drain-down.
