06-20-2022, 07:49 PM | #1 |
Drives: 2017 Camaro 1LT V6 Manual Join Date: Feb 2019
TR3160 Floppy Shifter Rebuild or Replace?
I need some help with exactly what's going on and what parts need/can to be replaced.
I have a 2017 V6 with the TR3160. All of the sudden the shifter has gone almost completely floppy. Doesn't matter if its in gear or not it is super loose. It still shifts into all gears just fine but I have to be deliberate and guide it into each gear. Its as if a spring or bushing is gone all of the sudden. I've been searching all day for replacement parts. I found the entire shifter assembly or just the Hurst short throw kits. Is anyone familiar enough with the entire mechanism to tell me if there is a rebuild kit available for this or am I just better off ordering a whole new shifter assembly? Does anyone have an exploded view of the shifter assembly? Video I took of the floppy action and shifting in and out of gears. https://youtube.com/shorts/WlKQ4SrQHnc Last edited by Danelt2017; 06-21-2022 at 12:57 PM. Reason: Add additional question |
06-21-2022, 09:35 AM | #2 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
How many miles do you have.I have 32 k on mine and it feels like when new , kinda sloppy and rubbery. I know this transmission is used in some mustang v8's including 5.2 voodoo with modifications. Surely it shifts better in a $60k car.I would like to know if parts are interchangeable.
06-21-2022, 09:40 AM | #3 | |
06-21-2022, 10:03 AM | #4 |
I had a Datsun 210 that was worse. A mechanic replaced plastic grommets where the stick goes in transmission.It worked great after that . I'm thinking the 3160 has rubber grommets that should be replaced with plastic or alloy grommets.
06-21-2022, 10:24 AM | #5 |
Your post made me think I can replace the grommets with harder ones if it is like the Datsun which I think it should be. I'm going to look into it.
06-21-2022, 11:24 AM | #6 |
The stick on 3160 has a linkage, no cables. GM parts has a 1le shifter for $277 or maybe bushings need to be replaced.
06-24-2022, 05:54 PM | #7 |
Drives: 2018 CHEVROLET Camaro LS LGX/TR3160 Join Date: Apr 2019
I replaced my shifter assembly after it started rattling, and it wasn't the shift knob bolt. The large bushing on the joystick side walked out of the boss and the control rod started riding on that boss. I replaced it with a Hurst short throw and has been fine ever since. I think GM missed the mark with that shifter assembly just a tad...Replaced at 45k, now at 105k
LorenZo
2018 CHEVROLET Camaro LS -The Giant Black SEALION- LGX/TR3160 w/BOZE!!!!! ig: rapidtransit |
06-28-2022, 07:11 PM | #8 |
I found the issue, need help locating part
After reading every post I can find on the shifter and this same or similar issue, I got under the car. The issue is with the two bushings pictured below. I took pictures under my car and screenshots from the Hurst Short Throw shifter install video. Both of these bushings need to be replaced. I am going to do it myself if I can find what these are and order them. Any ideas? I have not gone to the parts store nor the dealer as of yet. I have been looking but don't know the part number and finding pictures on listing is next to impossible so far.
Video for reference, started at 10:33. Pause there and you can see what I am showing in the pictures. https://youtu.be/RVeMXjma-lM?t=633 Hopefully these illustrate the part I am looking for. |
11-23-2022, 03:31 PM | #9 |
Drives: '18 RS 2LT, V6 M6, NPP, CAI, Brembo Join Date: Aug 2022
I had the same problem with a floppy shifter and created the solution after many hours of figuring out the problem and testing... New aluminum linkage bushings. Because guess what, when you spend the $2k to install the new shifter it will just happen again. This is the permanent fix.
video of mine installed: https://youtu.be/HJQYTn8phkY Order Here. Next batch arriving end of December https://www.fullmetalbushing.com/ other posting with this same discussion: https://www.camaro6.com/forums/showt...=607655&page=3 Last edited by Mellowjive; 12-08-2022 at 12:36 PM. Reason: updated link |
11-23-2022, 05:27 PM | #10 | |
11-24-2022, 08:57 AM | #11 | |
I notice now you have the funny video with the fart sounds. My son got a kick out of that. Do you mind if I use that as the reference video for this issue? I never recorded my shifter before the fix :( Last edited by Mellowjive; 02-03-2023 at 07:04 PM. |
11-24-2022, 09:10 AM | #12 |
You absolutely can use that video for reference. Glad someone else thought it was as funny as did!
11-24-2022, 09:25 AM | #13 |
Just put in my order. Thank you for putting in the work and getting this out! I am very much ready to get my shifter back to normal.
11-24-2022, 09:53 AM | #14 | |
Will keep you updated on timing. I expect to place the mfg order on Dec 12th. In the meantime I'll throw the car on a lift and make an overview video on how to install. Update: 1/1/2023 - Happy New Year everyone. Orders received through December officially shipped and I have a few more sets currently in inventory. I got to the auto shop and video'd the overview of installation. Hope to hear some feedback from others on how they like the hardware after their install. Thanks Last edited by Mellowjive; 01-01-2023 at 06:25 PM. |
Tags |
shifter, tr3160, transmission, transmission help |
