11-14-2021, 08:41 PM | #1 |
Drives: 2011 Camaro Join Date: Dec 2020
Cross member
Putting a carburetor and 5.3L in 2011 for drag strip only. Oil pan is hitting cross member before engine mounts touch frame. Guessing 1 1/2 - 2" off. Stock aluminum mounts with BMR solid mounts. Can I cut out the cross member all together and forget it?
11-14-2021, 09:16 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Not sure I would cut it out all the way. You could make some mounts to drop it down or cut it and have a drop welded to each side. There is a thread floating around here somewhere where someone has done this.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
11-14-2021, 09:42 PM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
cut mine out years ago no probs...using prothane engine mounts
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
11-14-2021, 11:19 PM | #4 |
Is that a custom pan for the strip or is it the stock 5.3 truck pan?
If the truck pan, why not swap it for the LS3/L99 style pan?
11-15-2021, 05:44 AM | #5 |
I did stumble upon the thread where guy made a custom bolt in piece. That may be option as well.
And yes assuming engine builder put a truck pan on instead of stock pan. Just wanted to get opinions to easiest solution at this point. |
11-15-2021, 06:30 AM | #6 |
11-15-2021, 07:07 AM | #7 |
Cam install...easier to drop pan and get to oil pump p/u...
11-15-2021, 03:45 PM | #8 |
11-15-2021, 05:06 PM | #9 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Cut your cross member and add brackets to make it a bolt In.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
11-16-2021, 12:19 PM | #10 |
Wasn't someone here making a kit for that exact setup?
I would buy it in a heart beat.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
11-16-2021, 12:31 PM | #11 |
CFD made them. He doesn't post a lot on here anymore so you might want to try a PM.
https://www.camaro5.com/forums/showt...&highlight=cfd |
11-16-2021, 03:06 PM | #12 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
This is the one I got from CFD.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
11-16-2021, 05:28 PM | #13 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
The OP isn't needing to cut the cross member because he wants to drop the pan, he wants to remove it because the oil pan he has needs another 1 1/2 clearance to clear the deeper oil pan.
Thus, he would need to replace (or eliminate) the current crossmember with one that drops down to clear his pan. |
11-16-2021, 07:47 PM | #14 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I would get an LS3 pan and pickup. I got a take out off eBay from one of the vendors for about $100. Of course they are double that now.
Or save a couple hundred bucks and break out the sawzall, but you can bet GM did not put that crossmember in just for shits and giggles.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. Last edited by CamaroCracka; 11-17-2021 at 08:10 AM. |
