08-27-2020, 10:58 PM | #1 |
ZL1 Manual specific driveshaft loop
2014 ZL1 Manual. stock NPP exhaust pipes up to headers with offroad pipes
Metco said they dont offer one and according to my Camaro mod book for the 5th gen, BMR wont work either. Has anyone bought an off the shelf driveshaft loop and installed without modification into their ZL1? All I see is modified SS cars. Thanks
08-28-2020, 06:39 AM | #2 |
Drives: 2014 Camaro ZL1 Red Hot Red Join Date: Oct 2016
Competition Engineering (Moroso), easy to install, fits perfect and no modification required. Part number C3174
08-28-2020, 10:16 AM | #3 | |
You have this on your ZL1?
08-28-2020, 10:47 PM | #4 |
Drive Shaft Loop
Hello,
I installed the BMR drive shaft loop on my ZL1, I have ARH headers and cat. back system. |
08-29-2020, 12:16 AM | #5 | |
What's the part number?
08-29-2020, 12:15 PM | #6 |
I have the competition engineering on my ZL1, manual, cross member goes back in stock. Only some spacer that are added. Go to the web site and look at the installation instructions
08-29-2020, 12:27 PM | #7 |
Thanks, Hopefully theres only one type to choose from. C3174 looks like it,
08-29-2020, 09:37 PM | #8 |
DSL014 - Driveshaft Safety Loop, Front, V8 Manual
https://www.bmrsuspension.com/?page=...465&superpro=0 |
08-29-2020, 10:04 PM | #9 | |
This is the issue I have and then they talk about the DSL015! So why the difference? So you didnt have to modify this DSL014?
08-29-2020, 10:11 PM | #10 |
Even the Moroso c3174 says fits non ZL1 models...something tells me I just need to bite the bullet and prove them wrong. Sounds like you guys figured it out.
08-29-2020, 10:49 PM | #11 | |
Not sure what you meant by a convertible frame brace. Would I need that to make the BMR to work? Thanks
08-30-2020, 09:47 AM | #12 | |
Brace
The loop fit with no issues or problems, I took a chance and ordered it, it fits fine with ARH header system with X pipe, I think it hits the stock ZL1 exhaust cross over piece. I ordered and ainstalled the convertible brace later to reduce any frame flex, what is good for the convertible has to be good for the coupe... I did have to put in some spacers at one end of the convertible brace to keep it even (the red pieces), as the transmission brace gets spacers from the BMR loop kit. I also cut holes for the O2 sensors to clear. Hope this clears things up Last edited by Vicster; 08-30-2020 at 09:59 AM. |
08-30-2020, 10:04 AM | #13 | |
Just kidding
10-11-2023, 11:01 AM | #14 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
https://www.detroitspeed.com/product...DNO1P-FbMtdPv4
Went with this one , alittle more spendy but says it works with zl1 and aftermarket drive shaft . Cleared it with gulf coast for my drive shaft , says has about 1/2 -3/4 clearence at the highest point . Loop is 5” Sorry bout bringing up an old thread just thought it would help peeps in the future .
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
