05-11-2020, 05:41 PM | #1 |
Drives: Chevy Camaro 2015 2SS RS Join Date: Feb 2020
Initial Tuning Cost?
So I am looking into getting a tune after getting a performance exhaust and cold air intake. I was wondering if $1100 for initial tuning and dyno is normal.
Apparently they told me that the first tune always costs the most (because it needs to unlock something)? is this true? i got an l99 engine, thanks |
05-11-2020, 05:55 PM | #2 | |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
05-11-2020, 05:58 PM | #3 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I’m paying 600$ for my FI build, and that includes an e85 tune also... they want to 3===@ (__*__) Right there...
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
05-11-2020, 06:02 PM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
That is an insane amount of money for just tuning.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
05-11-2020, 06:05 PM | #5 |
Ya, I'm still pretty new to this, but mainly I just want to tune out AFM. How much will that cost generally?
05-11-2020, 06:10 PM | #6 | |
05-11-2020, 06:12 PM | #7 |
USA-1
Ok, so...talk to RDP Motorsports and get this: https://www.rdpstore.com/p-6042-tune...tom-tunes.aspx
You'll upload the tune from your car into the tuner, move the tune file from the tuner onto your computer, email him the tune, he'll tweak it for your mods, send it back to you, and then you upload it into your car. Done. I've been using his stuff for 3 years now and only paid one time. I initially got a tune for an intake, then a tune for longtubes, then a tune for 3.91 gears, then a tune for my 3200 converter...and I still only paid ONE time. It's a no brainer in my opinion. Now, if you get a cam or supercharger he won't do those remotely, but it is what it is.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
05-11-2020, 06:16 PM | #8 | |
thanks tho |
05-11-2020, 06:58 PM | #9 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
You should only pay 1/4 of that for a tune. That’s crazy
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
05-11-2020, 07:05 PM | #10 |
You could buy a handheld from DynoSteve for $400 and get free tune updates for life. But, I don't know if he will tune for customers that live in California.
You do not need a dyno tune for light mods such as this, unless you are determined to get a dyno sheet and power results. But whatever way you go, $1100 is a crazy price to pay for tuning with those mods...or any, to be honest.
05-12-2020, 07:07 AM | #11 |
Drives: 2013 Camaro SS Vert Join Date: Apr 2019
I totally agree with everyone saying to get with Dynosteve at RDP. I have gotten 3 tunes myself and have 2 club members that have gotten tunes and everyone has been spot on. Since you have a L99 the trans tune is worth it alone. Stock the L99 shifts soft and doesn't really get the power to the ground. With RDP's tune drive is how it should shift from the factory and sport mode is neck snapping mustang eating aggressive. The lifetime tune is great if you plan to build in stages.
05-12-2020, 07:27 AM | #12 |
Started#gottalovethatblue
Yes an initial tune costs more because you have to unlock your ECU in their system, but HELL NO $1,100 is not normal. I know things in California are inflated but that's insanity.
As for Camarokid1996's comment, a tune is absolutely worth it even without headers and since you're in California I doubt you'll be able to get headers. For a L99 car a properly tuned car is a night and day different animal compared to a stock car because of how they tune the transmission. In stock form the automatic trans is a bit lazy IMO. With a quality tune the car will wake up and you'll think you picked up 50+rwhp. You can even have your tuner tune a "wife mode" in like I had mine do. What that means is that when in "D" mode it shifts smoother like factory, better shift points and a little firmer, but still smooth. However, in "M" mode it has hard neck snapping shifts that really turn the car into a bit of an animal. Good luck and stay away from that first tuner. That may be their "I don't actually want to tune your car but if you'll pay me a crazy price I'll do it" price.
05-12-2020, 06:28 PM | #13 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2016
I paid $800 less than that but was a street tune, so much fun and lots of knowledge gained with tuner next to me while I was driving
05-13-2020, 12:41 PM | #14 | |
Thank you for your reply, now I know what is possible. The cost of the initial tune also has 2 dyno runs included. so the $1100 price maybe because of the 2 initial dyno runs? |
Tags |
cost, dyno cost, question, tune, tuning |
