07-23-2019, 01:26 PM | #1 |
Drives: 2019 ZL1 1 LE Join Date: May 2018
ZL1 1LE CAMBER ADJUSTMENTS
OK Guys, On the 1LE there is a street and track setting for camber. What GM Didn't tell us is there is an additional adjustment for camber. After ruining my new 3r's on my third track day with the car I found out how to adjust the camber.
I'm an experienced driver and just got the 1LE recently. Anyway to get to the point first you have to buy a camber adjusting bolt from the dealer. Here is a copy of how to do it. Hope this helps everyone. Many Thanks To Ben the Mechanic who helped me with this. Once the camber bolt is installed loosen the two red bolts to adjust camber and then re-tighten. You can use a long extension and go between the rotor and wheel to adjust while aligning. You can see the hole if you look above the rotor through the wheel. Last edited by Johnkout1; 07-23-2019 at 01:36 PM. |
07-23-2019, 01:35 PM | #2 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
This has been the same since 2010 for 5th and 6th gen camaros for front camber adjustment. Any competent alignment tech should know this. And gm defiantly has had this listed in the service manual for about 10years now.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
07-23-2019, 07:42 PM | #3 |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Yeah I am with ICTsccaCamaro. This is standard stuff. Also the camber adjusting bolt is just a standard bolt with the matching thread pitch that threads in and pushes on the knuckle.
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
07-23-2019, 07:55 PM | #4 |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
I don’t get the camber bolt, it looks like if you tighten it, you push the knuckle away from the strut for positive camber.
07-24-2019, 07:50 AM | #5 |
ITCRNRS
You are correct, tighten the bolt to remove neg. camber and loose the bolt to add neg. camber.
07-24-2019, 01:24 PM | #6 |
Drives: BMW M3, ZL1 1LE Join Date: Mar 2019
You can adjust camber without that bolt. It just makes things a bit easier to dial in.
07-24-2019, 02:55 PM | #7 |
Drives: 1985 Oldsmobuick Join Date: Oct 2012
Whats the part # for this bolt?
07-24-2019, 03:11 PM | #8 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
If you're an experienced driver, 3r's usually don't last more than 3-4 days on track. The fronts wear very quickly.... period.
Yes, front has the camber plates and the traditional strut adjustment as well. No bolts needed. Last edited by Provoste; 07-24-2019 at 08:15 PM. |
07-24-2019, 08:26 PM | #9 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
On my Gen5 I use a 10mmx1.5x30mm stainless set screw on each knuckle. The thread size is the same for the Gen6. I do not know if the 30mm length would work on a Gen6. I leave mine in the knuckle with some Loctite.
07-24-2019, 09:44 PM | #10 |
Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
Don't forget the TTY replacements...
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD |
07-24-2019, 09:48 PM | #11 |
Drives: ZL1 1LE Join Date: Oct 2016
You don't need a special bolt to adjust camber on this car my man. ALSO, the 3r's cord on the inside regardless. It is NOT an alignment issue. I'm starting to think there is some toe adjustment under load or something that destroys the tires. unfortunately, if you track this car get used to replacing tires. I only get 6-7 sessions per front set.
07-25-2019, 04:56 AM | #12 |
Thank you Al Oppenheiser!
Or maybe it's just a heavy car and under corning load there's just a lot of load on the front outside tire. But what do I know, I don't track my vert.
Can't wait to see all the new c8 owners bitch about how fast there new cars eat back tires with the rear weight bias. <3 sec 0-60 comes at a price. |
07-25-2019, 06:39 AM | #13 | |
Drives: '19 ZL1 1LE Join Date: Feb 2019
Big, heavy car with a lot of weight on the nose - I guess it is to be expected. |
05-11-2024, 10:07 AM | #14 |
Drives: 23 ZL1 1LE Join Date: Jul 2023
Camber adjusting bolt part number?
Hi wondering the part number for a zl11le camber adjusting bolt?
Thank you. Black zl11le |
