06-02-2024, 10:12 PM | #1 |
Drives: 17 Volt, 20 Mustang, 2015 Boxster S Join Date: May 2023
Bridgestone RE71RS 285/305 Tested?
I am autocrossing a 2024 1LE with 19 inch 10/11 fr/rr rims. I have a set of 285/35/19 at all four corners. I am considering adding trying some 305/30/19s on the rear. Has anyone tried this set up for autocrossing or track? Our cars come with taller rears and this is shorter rears but wider for a little more grip. Will this work?
06-03-2024, 12:21 PM | #2 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
the 305/30R19 will be shorter overall diameter then the 283/35R19 front. From what I've seen and been told, the ABS and stability system will not like this because the rear tire will always look like it's rotating faster than the front tires.
06-03-2024, 02:19 PM | #3 |
Drives: broken Join Date: Aug 2009
There is someone running the 285/305 combo and having decent results. The diameter difference doesn't appear to cause issue when TC/ECS are disengaged. Not sure there's enough data yet to draw conclusions about whether it's faster (or slower for that matter) than 285s all around.
clyde
Team WTF?! what are you gonna do? :dunno: |
06-03-2024, 11:50 PM | #4 |
Diameter difference
Yes the original size tires are 285/30/20 and 305/30/20 with diameters of 26.8 front and 27.2 rear 3.7% difference. 286/35/19s are 26.9 inches f/r, so 0% difference. The 285 fr and 305/30/19 rear are 26.9 and 26.3 inches which is now a 3.4% difference but now about 7.1% difference front to rear from stock. What I have heard (read on this forum) is that most of the people at nationals run with all nannies off so no impact on tire diameter difference. Theoretically then, the larger 285/305 difference will not matter with nannies off but more rear traction should help. Still I appreciate any input and thoughts.
The Chevy engineers (from traction modes explained on this forum) said that Track/Race mode is the fastest with PTM on and everything else off. Will the 285/305 setup effect PTM? I have tried Track/All off and Track/Race with no clear winner the one day I played around but I am still learning the car. Last weekend I was 25th and 18th in Pax out of about 120 people each day. |
06-04-2024, 03:42 PM | #5 |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
Where did you get the 1LE door handles??
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
06-04-2024, 06:37 PM | #6 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I ran 305s on a 19" x 10/11 setup with no issues.
06-04-2024, 11:44 PM | #7 |
06-06-2024, 12:05 PM | #8 |
I had made them myself. Used vinyl wrap and cutout 1LE letters using templates. Then wrapped over top of those letters around the entire handle to create the 3D look.
06-06-2024, 01:12 PM | #9 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
06-06-2024, 02:58 PM | #10 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
running this exact setup right now, only at autocross events and to and from the hotels lol.
I have had hard pedal once after the finish. other than that ive had full confidence in the brake and its surprised me. I expected more of an issue, with that said.... now ill probably have a ton of issues lol.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
06-06-2024, 09:25 PM | #11 |
I had the old 305/30-19 RE71R on the 10" fronts. First set took us a few sessions of attempts. Second set went a lot easier because we knew what to do: heat, Murphy's Tire Lube (and lots of it), dangerous inflation pressure, patience and commitment to see it through.
clyde
06-06-2024, 11:06 PM | #12 | |
Tire pressures?
06-07-2024, 10:58 AM | #13 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
If it helps, I run the same sq setup. Been using 33-34/32 hot, so about same as you. Seems to be best for me so far. But still 1/8” above arrows as the sidewall is stiff on the 10.75” wheels, maxed out camber and hotchkiss front bar, so take that into account. I am trying 32/30 next time to see how it does.
06-08-2024, 10:14 AM | #14 | |
