12-12-2021, 04:09 PM | #1 |
D3RPZILLA
ZL1 1LE diffuser vs ZL1 diffuser
Does anyone happen to have the OEM part number for the ZL1 1LE satin/matte version of the rear diffuser? I plan to swap the front lip/grills of my ZL1 to the ZL1 1LE better flowing versions and would like to match the satin/matte look of the front to the rear diffuser (and will have the side skirts or whatever they are called satin/matte wrapped to match (well, at least get close to matching).
I've found this: https://www.gmpartsnow.com/oem-parts...cover-84306917 But it's description is just "With perf exhaust, with zl1." so not sure?? Lol. Thank you!
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy YouTube Playlists: Performance Mods | Show Mods | Other Mods |
12-12-2021, 04:46 PM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Easier solution is to have the 1LE front splitter painted to match the ZL1 side skirts and rear diffuser. That's what I did.
12-12-2021, 05:04 PM | #3 |
D3RPZILLA
Yeah, I'm also leaning towards that, but does the canards, grill, the piece that replaces the day time running lights section, etc, all in matte/satin look weird with gloss lip?
12-12-2021, 11:07 PM | #4 |
D3RPZILLA
Kind of like the satin look especially for durability if I tag the lip on the ground a few times it seems it would hold up better than if I get it painted and what not, lol.
12-13-2021, 04:24 AM | #5 | |
12-13-2021, 09:53 AM | #6 | |
D3RPZILLA
Also considering maybe doing a thick ppf style vinyl wrap of carbon fiber weave on the lip to match the heat extractor. Hmm.. If I did that I'd also do the canards and the inlet pieces.
12-13-2021, 10:13 AM | #7 | |
12-13-2021, 03:00 PM | #8 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
12-13-2021, 03:16 PM | #9 |
12-14-2021, 10:31 AM | #10 |
Drives: 2022 Camaro ZL1 Join Date: Nov 2021
12-14-2021, 10:46 AM | #11 |
12-14-2021, 10:48 AM | #12 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The rear diffuser is the same part between ZL1 and ZL1 1LE. Just as the side skirts are the same part between ZL1 and ZL1 1LE coupe (the convertible ones have a slightly different internal mounting bracket, which can be swapped out BTW). The difference is just the metallic black with gloss clear vs black with satin clear paint. You don't can't order those parts from GM pre-painted.
12-14-2021, 10:52 AM | #13 | |
D3RPZILLA
I probably will just get the lip vinyl wrapped or something with some thick protective wrap, maybe carbon fiber weave or something to match the heat extractor, and maybe the canards as well.
12-14-2021, 11:33 AM | #14 |
It's probably $300 worth to get the rear diffuser painted in black + stain clear. That's removing the rear bumper and removing the diffuser and dropping the diffuser off to a paint/collision shop. However, I will tell you the ZL1 rear diffuser is a small pain to remove and re-install to the rear bumper - you almost end up breaking off two of the tabs from the bumper... you have to be pretty careful and strategic.
Tags |
diffuser, rear diffuser, satin, zl1 1le |
