08-25-2024, 08:43 PM | #1 |
Drives: 2024 Camaro LT and 2023 Corvette Z Join Date: Dec 2011
Add GM Navigation
My 2024 Camaro was ordered without Navigation.
Checked with odbgenie but their software upgrade does not support the 2024 due to new bus protocols. Does GM offer an upgrade to add Navigation? Thanks |
08-25-2024, 09:00 PM | #2 |
I used OBDGenie's NAV upgrade for my 2022 and it works great. I'm surprised Chevy made any changes to the 2024 since it was end of life.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
08-25-2024, 09:02 PM | #3 |
jfkheat
Drives: 2023 Rapid Blue ZL1 Join Date: Nov 2023
When I traded my 2024 2SS, according to the dealership's ad when they listed it, they upgrade the system to include navigation. I have no idea how they did it. I would call your local Chevy dealership service department and ask someone there.
08-25-2024, 10:02 PM | #4 |
In before the uninvited "why don't you just use waze / google maps / apple maps" crowd
There was a navigation upgrade package for 2019+ model years (with the newer 3.0 infotainment that uses an SD card for maps), asking your dealership is your best bet indeed.
08-25-2024, 10:35 PM | #5 |
Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
do you have the IOS radio (8" screen) or the IOR radio (7" screen)?
If you have the IOS you can update it to have navigation(IOT radio) to the best of my knowledge. The software from the IOT can/does run on the IOS radio. Though you may also need to replace your usb port connector with one that also includes a slot for a SD Card. Looking at a parts site it also definitely looks like the 2024 does use the same radios as previous years. So if you do have the IOS radio you might want to doublecheck with ODBGenie or also could recommend reaching out to White Automotive Media, though they will require you sending in your radio control unit for programming. |
08-25-2024, 11:34 PM | #6 |
My 2024 Camaro has the IOS radio and a slot in the console for the Map SD card.
Will check with my dealer and/or Chevrolet about adding it. Thanks |
08-26-2024, 05:01 AM | #7 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Check with WAMS, White Automotive and Media Services. They added NAV when I added PDR to my '22 SS 1LE.
08-27-2024, 11:17 AM | #8 |
This is what I received from OBD Genie:
Your vehicle is built with 'Can-FD', that is the ultra secure system that GM has introduced and no one can communicate with. I'm sorry, but our G-NAV upgrade will not work on your vehicle. |
08-27-2024, 11:36 AM | #9 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
I looked at their website and don't see an option to add the PDR. How were you able to add that?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, RPI Designs SS 1LE Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
08-27-2024, 02:22 PM | #10 |
Electrical Engineer
Wireless Android Auto or CarPlay does a pretty awesome job with on-screen maps and navigation.
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 34k mi. @ Sept 2024 New Engine @ 22,600 mi. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
08-27-2024, 02:23 PM | #11 |
They do not have it on their site because it is not just a software upgrade. It is hardware also and GM has no support to add it to vehicles where it was not an installed option. A very small number of us have added it. There is a thread here on the forums with info. It is not a simple install.
08-27-2024, 04:59 PM | #12 | |
08-27-2024, 08:44 PM | #13 |
I think it depends on one's skill level. The beginning of that thread is more complicated than it really is. If you get the right parts and harness, it's not bad, then it is kinda plug n play followed by the right radio module programming. There's are few components that are not easy to procure though.
09-06-2024, 05:10 PM | #14 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2016
I'm glad i found this thread. My ZL1 did not come with navigation and it has been bothering me. I ordered from OBDGENIE and I can say that it does work!
The map seems to be a few years out of date though. It is easy to do. The hardest part is finding the sd slot and inserting the card properly (it goes in upside down). https://www.obdgenie.com/collections...31708515270729 |
