![]() Drives: '22 Chevrolet Camaro 2SS 1LE Join Date: Aug 2023
2022 Camaro SS 1LE. This past May I put on some headers and had it tuned for E-85. These past almost 4 months it's run flawlessly with no problems. Last week I noticed it would kind of strutter to start and sometimes I'd get a P2270 (Bank 1 Sensor 2 stuck lean). My tuner told me he'd get to it eventually, but we haven't gotten to come together for it. A few days ago I remote started it and it noticably struggled hard to start and I got a P0300. It was pretty constantly missing on 3 and sometimes on other odd cylinders. I noticed it wouldn't miss with any load on it, but when at idle it would constantly miss on 3. I haven't driven it since. I swapped plugs, wires, and coils to another cylinder and I thought it followed, but doing it all again it is still on 3. The plug on 3 looked like it got very hot and had a whitish color, while cylinder 1 looked a bit rich. Compression on cylinder 3 is 210 p.s.i., I have codes P0300, P2270, and P0172.
If it were a tune issue, wouldn't it have shown itself a long time ago? If it were a leaking injector, it should've hydrolocked by now, as I've let it sit for a couple days before starting it, also the plug wouldn't have looked so hot. If it were something in the ignition system, it should've shown itself when I was swapping stuff. Power to the coil is good as it resistance checks perfectly. I'm worried it's a mechanical issue as everything I can tell checks out. It seems obvious that something is causing the bank 1 sensor 1 to think that it's running super rich and is causing the ECM to take a bunch of fuel away. I think it's localized to cylinder 3 as the spark plug looks vastly different (image below). I just done understand why it got gradually worse. I'm so lost and so is everyone else I talk to about it. Am I missing something? Please help! TIA! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Sounds mechanical and possibly an Injector issue
2016 NFG 1SS A8
Well tunes don't magically change. Just because it has compression doesn't mean something else isn't wrong. I suggested injector because the fuel trims are way off on one bank only and you have a misfire. Not to mention DI injector failures are not uncommon on this platform.
2016 NFG 1SS A8
![]() Drives: 2010 camaro Join Date: Dec 2017
yup Injector(s) issue! Drain the fuel if you can and but some 93octane with fuel cleaner like techron or shell's v power fuel treatments. let it idle and drive for 3 miles it. you may be able to get away with it as the injectors will spray 93 fuel running and cleaning out the fuel system... , or you can buy new fuel injectors and it should most likely fix the issue. good luck!
Tags |
lean, misfire, p0172, p0300, p2270 |
