03-18-2022, 02:06 PM | #1 |
Drives: 2016 camaro 3.6 Join Date: Mar 2021
Liquid Moly oil
Compatible with 2016Camaro V6 ?
Any thoughts |
03-18-2022, 02:51 PM | #2 |
Scenic City Camaro
Drives: 2022 Camaro ZL-1 /1974 Firebird 400 Join Date: Jan 2014
Stick with the oil the owners manual says as far as viscosity. Brand name is probably not important.
2022 Camaro ZL-1, grey
1974 Firebird Formula 400, white https://www.facebook.com/groups/Camaro/ https://www.facebook.com/CRFinTN/?modal=admin_todo_tour |
03-18-2022, 08:00 PM | #3 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
^Pretty much that.
Honestly, I find Liqui Moly a bit too expensive to really justify the cost, and they have a lot of products that are... too interesting for my taste, to put politely. Personally, I tend to lean to Pennzoil for other cars I had but for my SS 1LE, I kinda have to stick to Mobil1 ESP 0W-40 because of Dexos2. But if you are doing street driving, anything with the right viscosity and certification from big brands will do.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
03-18-2022, 11:20 PM | #4 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
03-19-2022, 04:28 AM | #5 |
Drives: 2017 2SS F1FTY Join Date: Feb 2020
Does anyone find it interesting that there is literally only one oil that that is 0w-40 dexos 2?
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
03-19-2022, 05:33 AM | #6 |
Love my Satin Steel LT-1!
Drives: 6-Speed LT-1... Join Date: Aug 2016
The LGX V6 uses 5W-30 Dexos 1 gen 2 oil. There are a lot of choices, unlike the 0W-40. Moly is expensive and the V6 is fine with a cheaper oil.
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels Technology Pkg|NPP|Satin Blk Pkg ZL1 Rock Guards|Red Knee Pad Set PBC LT1 engine built by Debi Lewis |
03-19-2022, 08:58 AM | #7 |
Hot Camaro
Kirkland / Costco oil was typically about $25 for 10 quarts (two 5 quart jugs) and that's actually what I've been running in my LT1 motor (SS) with zero issues (the 5W-30 is Dexos1 is fine for street use).
03-19-2022, 09:00 AM | #8 | |
Hot Camaro
Remember that this is a certification, not a forumalion, and it's "pay to play." In other words, GM's strict requirements are a good thing, but the heavy cost of certification for a limited set of engines that "require it" doesn't make sense for most manufacturers. Additionally, the dexos2 oil is -ONLY- required for track use in some of the models. |
03-19-2022, 09:29 AM | #9 |
I checked their website, the 5W-30 they recommend for the LGX is API SP compliant and has a dexos 1 gen 3 recommendation (apparently gm will switch from dexos 1 gen 2 that is usually referred to as "dexos2" to these new requirement specs starting September 2022), so I wouldn't worry about running it if I had a V6.
Not particularly cheap, but based on the detailed technical info at that site, it should be fine.
03-19-2022, 12:42 PM | #10 | |
https://www.gmdexos.com/brands/dexos2/index.html To make matters more confusing, the Castrol Edge A3/B4 you find in North America is NOT certified with Dexos2. AFAIK, the variant that is certified with Dexos2 is not sold in North America unless someone manage to import some from other markets. If you are good with 5W-40, Motul has oils that is certified with Dexos2. What you said in the latter half makes sense, and is the argument Amsoil makes for their oil. They meet the certifications, but they don't want to pay for them. People who are willing to buy will buy them anyway. I do horse my car around the track from time to time, so I would have to stick with 0W-40 Dexos2. 5W-30 is fine otherwise for street use only.
Current:
03-19-2022, 03:40 PM | #11 | |
Hot Camaro
Do you change your oil after the track time? If so, you could swap back to 5W-30 dexos1 to head back onto the street. The High Perf Supplement actually discusses changing between the two based on street or track, so that's fully 'supported' in the eyes of GM. |
03-19-2022, 04:16 PM | #12 |
Guys, OP has a 2016 V6. No high performance supplement at play here, 5W-30 is plenty good for the LGX.
03-19-2022, 04:58 PM | #13 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
03-19-2022, 08:41 PM | #14 | |
As for the track oil, I don't change oil after each track day as that is pretty excessive. 0W-40 Dexos2 is good for both street and track use. It is a do-it-all oil for those who both DD and track their car.
Current:
Tags |
oil |
