05-20-2020, 07:04 PM | #1 |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
Differential Fluid
Has anyone changed their Differential fluid since they bought their car new? Is it supposed to be drained and refilled after a break in period? I'm thinking it doesn't.
05-20-2020, 07:14 PM | #2 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
I did because of the e diff in the 1le, better safe than sorry
05-20-2020, 07:55 PM | #3 |
Drives: 2018 Camaro 1SS 1LE Join Date: Feb 2020
Mine was changed at 1000mi and 6000mi, but also a 1LE.
05-20-2020, 08:30 PM | #4 |
500 then again at 1000
05-20-2020, 08:34 PM | #5 |
Well, damn! I have over 1,000 miles on mine and I haven’t changed the diff fluid. I hope my diff doesn’t lock up on me and leave me stranded. Lol. Does it say to change it that early someplace? I have not read that anywhere, but I can’t honestly say that I’ve read every page of the manual either. Seems a little excessive to me.
05-20-2020, 08:40 PM | #6 |
ask any diff builder.
05-20-2020, 09:06 PM | #7 | |
LT1 1LE
Drives: 2018 2SS 1LE HPB Join Date: Apr 2018
Most here are hedging to be on the safe side. I drive my car hard but have not yet tracked it. I've also not changed the diff fluid (also called rear axle fluid, according to the manual). |
05-20-2020, 09:25 PM | #8 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
This function does wonders
05-20-2020, 09:39 PM | #9 |
Drives: 21 SS Join Date: Oct 2017
Doubt a mass produced car just driven on street needs this before manufacture interval. Road course use sure.
I did mine at 40k.
05-20-2020, 09:56 PM | #10 |
im not arguing with anyone. its a fact. Thats the problem with forums and why pros dont get on them. People talking about stuff they know nothing about. You can tell someone the answer but someone who wants to be cheap will argue to justify saving $20. Call a pro or pull the drain plug and see the metal and black oil. Gears need to break in on any car. Q the keyboard warriors.
05-20-2020, 10:02 PM | #11 |
2020 Shadow Gray 2SS
2020 2SS, I changed my oil and differential fluid at 505 miles, next change is at 1,500 miles (I don't track the car), then I will change every 3,000 miles after (might do the differential every 6,000 miles)...
My motto has always been... "Fluids are cheap, components are not..." (Disclaimer: I do my maintenance myself, so the cost of doing these changes for me is merely materials but an oil change is still a solid $100 and the diff is still something like $25...)
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
05-20-2020, 11:27 PM | #12 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
The first 1,500 miles is the Break-in period!
05-21-2020, 03:40 AM | #13 |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
I had the rear diff groan after a couple thousand miles. The TSB fix is a rear diff flush. The tech was shocked how dirty the fluid was considering the mileage on the car and he's used to changing fluid. I've had no noises since it was changed. If I had to do it over again, I'd change it at 500 miles at least and maybe once more after 1000-2000 miles.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
05-21-2020, 04:19 AM | #14 |
Drives: 2019 ZL1 Join Date: Feb 2019
Changed mine around 1400-1500 miles. I will do it again around 3000. Does it absolutely need to be changed that soon? Probably not but it's not difficult nor expensive and the peace of mind is worth it to me.
