10-04-2017, 09:14 PM | #43 |
i have the part number for the ground effects rear diffuser if you want. its expensive but if you really want it here you go: 23418858
10-28-2017, 08:37 AM | #44 |
Tazz3069 Did you get the rear portion of the GM Body Kit
10-28-2017, 08:56 AM | #45 |
Yes I did
2016 Camaro 2SS "Black Widow" |
10-29-2017, 11:31 AM | #46 |
Drives: 2017 Corvette Grand Sport Join Date: Aug 2009
Anyone consider doing a euro spec rear diffuser swap?
12-08-2017, 11:45 PM | #47 |
Drives: 2016 Camaro 2SS NGM Join Date: Jun 2014
12-08-2017, 11:51 PM | #48 |
12-10-2017, 01:18 AM | #49 |
12-10-2017, 06:49 AM | #50 |
No, it is a kit. Last i knew it was not obtainable by itself, unless you found a re-seller who got the kit for other pieces and didn't need certain parts(like body shops, dealers who are fixing other damaged pieces).
Plus my rear diffuser section is a 2 piece section, it used 2 pieces to make one. Thou in an earlier post, the ZL1 diffuser is a one-piece. |
12-10-2017, 07:46 PM | #51 | |
12-10-2017, 08:35 PM | #52 | |
For Dual-single tips(mine), you cut off the factory chrome tip from each side and put on a small black tip and it sticks into an opening of the flat black inner/ chrome outer piece. Have to make sure the kits is for your exhaust code. |
12-12-2017, 10:47 PM | #53 | |
12-13-2017, 07:12 AM | #54 |
I actually have the Flowmaster American Thunder Axle-back Exhaust System on mine.
You still have to cut the tips off, because the single tip are too large and the diffuser is not made for it. Think Chevy did the modification as a way to not have to make 2 types of diffusers, just different chrome inserts depending on the type of exhaust tip within the diffuser. You can also if you have not changed the muffler exhaust, pick & choose the tip and get the body kit diffuser to match your choice. Just the single large tip will always need to be cut off as part of install. If you choose quad, then no cutting, just an install. |
12-13-2017, 10:59 AM | #55 |
So I could probabl y buy the quad and make it work with the single
12-13-2017, 11:35 AM | #56 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
As far as I know it is the same as the US one except the reverse light and the rear fog light.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
