10-10-2020, 02:40 PM | #15 |
Drives: 2017 Camaro 2SS Nightfall Gray Meta Join Date: May 2019
Okay awesome! I sent you a message! Also do y'all know if I will need any gaskets for the Intake Manifold? Since I will be taking that off?
10-10-2020, 03:18 PM | #16 |
Drives: '16 2SS Join Date: Feb 2017
If they're not damaged, you should be fine. I've reused mine going from stock to the MSD and then taken the MSD off and back on a handful of times with no issues yet.
10-10-2020, 05:28 PM | #17 |
Drives: 2016 Camaro SS 2017 Yukon Denali Join Date: Jan 2020
Pg 26 of the warranty book the op posted. States the injectors are covered under the 8/80 emissions warranty. I’d call gm
10-11-2020, 08:21 AM | #18 |
Thanks I appreciate that guys! I decided Screw it. I'm going to do it my self at this point I don't want anything to do with that FN dealership. When I had full warranty they barely wanted to work wit me when my head's had issues. My heads were porous. So I got a set of heads. They were leaking coolant in go the combustion chamber. It took 2 weeks of talking to them and finally calling gm for them to do the work. Dealers out here are aholes man.
10-15-2020, 05:57 PM | #19 |
Okay, update. After reading this thread
https://www.camaro6.com/forums/showt...T1%20injectors I bought my coworkers LT4 injectors. Wil put them in this weekend. I will also get a LT1 set hopefully, and see the differences! |
Tags |
fuel injectors, injectors |
