09-15-2015, 12:31 PM | #85 | |
Drives: 98 camaro turbo Join Date: Nov 2009
Just saying... I was speculating assuming that the PWR is infact "power to weight ratio" Either its a lt4 with 640hp - 650hp then the weight of the car is way over 4000lbs. or the Hp is mid 500hp's and its under 4000lbs. ... again that is all speculation.
09-15-2015, 12:32 PM | #86 | |
Drives: Current Camaro-less Join Date: Jul 2014
IE.."We tested it at 585, 600, 625, and 650 and found that the optimum was at..." |
09-15-2015, 12:40 PM | #87 | |
sure, but why would they need to plaster it on the side of the vehicle? im pretty sure they can put something like that on a post-it note in someone office, away from the cameras. |
09-15-2015, 12:46 PM | #88 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
It also says less than 6.46. It says less than 4.0 to 60 but the SS already does it in 4.0. The ZL1 better be way under 4.0.
09-15-2015, 12:49 PM | #89 |
Drives: 2017 2SS Camaro Join Date: Mar 2015
looks like a roll cage is installed!? Might be a requirement for the track after reaching 600HP? I don't know......
Why would the "test" it with a roll cage if it is in final design? (not saying it is, just my thoughts) Unless the seat belt retracts out of the roof like the 3rd gen. But it looks like a bar to me.... |
09-15-2015, 12:49 PM | #90 |
Drives: New Join Date: Sep 2012
Are we sure that this is the same car from these spy shots? http://www.leftlanenews.com/photos/c...icture-13.html Could they be working on 2 at one time?
09-15-2015, 12:54 PM | #91 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
09-15-2015, 12:55 PM | #92 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
anyway, if it is real... I'm hoping its a 580 HP, 3,750 lb NA Z/28. A 640 HP LT4 at 4,134 lbs wouldn't be consistent with what they've shown in the SS
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so. Ronald Reagan - |
09-15-2015, 12:55 PM | #93 |
IMO this is the next Supercharged Camaro don't know what they are going to call it, maybe a ZL1 or not, but it will be the successor to the gen5 ZL1, for power i say look for a LT4 coming in at 640 HP, and will come in at under 3900LB you do the math but if you can afford it buy one........
Grate time to be a car guy, this will slap the the $HIT out of anything ford.. |
09-15-2015, 12:56 PM | #94 | |
09-15-2015, 12:59 PM | #95 | |
Drives: 2011 Camaro 2ss Join Date: May 2013
09-15-2015, 01:12 PM | #96 |
Drives: Want a gen 6 Join Date: Jan 2013
Will they do partnerships with SLP again like Mustang/Roush?
09-15-2015, 01:17 PM | #97 |
I believe this is what the new shots are of, notice the hood bulge
09-15-2015, 01:19 PM | #98 | |
Drives: 2014 Camaro SS Join Date: Mar 2014
However, you still need to take that heated water and release it's heat somewhere - like a front mounted water-to-air heat exchanger. Water from the supercharger is pumped to this exchanger to release the heat absorbed from the intake air.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net |
