09-16-2015, 11:53 PM | #281 | |
Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
Currently GM owns the patent for the technology behind magnetic shocks.... However Delphi owned the trademark (the name) to magnaride (hence GM no longer calls its system magnaride). MRC was developed by General Motors... Delphi was originally Automotive Components Group, this was an entity created by GM in 1994. In 1995 GM changed the name to Delphi and in 1997 Delco electronics was pushed into Delphi.... While magnaride was being developed GM spun Delphi off, so by the time this suspension technology made it into its first car Delphi was its own entity working with some GM engineers to finish the project. It is more accurate to call this a joint GM/Delphi project since it was being worked on while Delphi was part of GM. Also Delphi was an entity that was created from the ground up by GM and did not exist until GM made it. http://www.google.com/patents/US8055408 This is the patent for the control system for magnetic shocks (the patent for magnetorheological shock absorbers dates back to 1948) means that neither GM or BWI owns the patent for magnetic shocks. BWI is using the magnaride trade mark to produce other magnaride suspension parts such as magnaride sway bars which will be interesting. |
09-16-2015, 11:59 PM | #282 |
Drives: 2014 Z/28; 2014 Ram 2500 CTD Join Date: Jan 2014
Carbon Ceramic need to be at proper operating temp to really get the bite and braking power they were purposed for. They offer supreme braking in extreme driving conditions. Using a good conventional steel 2 piece rotor would eliminate 5k to 7k in overall cost of vehicle.
2015 Silverado 2500
2014 Z/28 |
09-17-2015, 12:06 AM | #283 | |
2015 Silverado 2500
2014 Z/28 |
09-17-2015, 06:00 AM | #284 | |
09-17-2015, 06:04 AM | #285 | |
Drives: VW Typ 166 + Black 1LE Join Date: May 2007
I'm kindly asking: "May I have a supercharged Z28 with 550 hp please? By the end of 2009 would be awesome. Thanks"
09-17-2015, 10:09 AM | #286 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
The more I think about it, I'm pretty sure this will be the ZL1. If you compare it to the 5th gen ZL1, they are about the same. Both had an upgraded front fascia for cooling, a large heat extractor and some minor aero work.
09-17-2015, 10:18 AM | #287 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
I agree. What I still struggle with is the stance and tire/wheel package. That care looks to be even more track focused than the 5th Gen ZL1.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
09-17-2015, 10:23 AM | #288 |
The stance seems a little lower but the wheels seem to be similar in size.
09-17-2015, 10:31 AM | #289 |
Current has 20x10 and 20x11 with 285 and 305s if I remember correctly. I think those are 305s front and back which means the wheels are probably 20x11 in the front as well. The dish in the front wheels just looks deeper than the current ZL1/1LE wheels. Again, JMHO.
09-17-2015, 10:42 AM | #290 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Welcome to the dark side.
09-17-2015, 10:52 AM | #291 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
HP was code name for what originated as a Z/28 for the 5th gen, but they changed that up and made it a ZL1. Even some of the ZL1 parts have "Z/28" molded into them near the part numbers. Before the ZL1 was announced, on the Martinrea tour in Canada, we saw a HUGE pumpkin and rear carriage assembly off to the side. Obviously some of us got interested for more. All they would say is that it was for the "HP".
Additionally, when several people from the plant and myself were all sitting around in the parking lot at the 2012 ZL1 showing at the big Camaro meet in Oshawa, they were already working on a Z/28. They did not say what it was at the time, but a few of the workers told me about a lighter-weight version with limited options, and different glass. It was a non-supercharged version they were fitting the hood on that day. They said this one was going to be a beast. Turns out it was the Z/28. I was sworn to secrecy at the time, though. But now that it happened, I don't think it's such a huge deal about the secrecy. My personal thoughts on what we're seeing is - MULES. Not the factory versions. Not sure what they're testing with each mule, but my guess is that what we'll get is the ZL1, with an optional "track-pack" option called the Z/28 with different suspension, and maybe even a different engine. That's my guess. Reason why I think that is that the dismal sales figures that both the ZL1 and Z/28 had suffered by either being over-built or simply missed sales guesses. GM will build them, IF you go in and ask for it. In either case, with V8 in 2017 and the EPA rules, that means you will pay through the nose for one of these cars, no matter if it's a hybrid-Z or separate vehicles, or just one. Just a guess.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
09-17-2015, 11:29 AM | #292 |
Front tires are smaller on this car then the rears, is not that hard to tell, if they where same size, in a 1D pic they will look bigger then the rear's, and they dont that's why there smaller, look for the same size rims as the old ZL1 for this car.
Here is a pic of a Z/28 on the track look how big the front look compered to the rear, car is the same way as the 2017 ZL1 in the pics. |
09-17-2015, 01:42 PM | #293 |
Drives: 2014 Camaro SS Join Date: Sep 2013
Are we sure that this is the ZL1 and not the 1LE? The reason I ask is because I thought only the 1LE's had the hash marks on the side of the front fender. If I am wrong please do call me out on it.
09-17-2015, 02:40 PM | #294 | |
And besides, you can get fender hash marks on the 6th Gen SS, and probably others - check visualizer on chevy's site.
