Old 03-11-2020, 09:06 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by init4fun View Post
I'm an example of someone that had the the shudder return about 200 miles after TSB 18-NA-355 was done. TSB was applied in Aug 2019, I drove the car for a couple of days and the problem returned. Took it back and they replaced the transmission, converter and obviously new fluid. So far I only have about 400 miles since that was performed. Just took the car out of storage last Sunday. Will keep you posted.
FYI, There were several revisions to that TSB...good chance your dealer used a previous method instead of the new flush tool with mobil 1 blue label fluid. Fwiw The latest revision to that TSB wasn't published till August of 2019.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-13-2020, 01:45 PM   #16
PhantomV8
PhantomV8's Avatar
Originally Posted by MarkSS1958 View Post
Had the shudder with a 2017 Silverado .GM bought it back as I agreed to buy another GM .I specked out and ordered factory direct a Sierra it had the same problem. Did the Lemon Law process during mediation the GM rep stated that it was my imagination . Anyway I won and they bought the second one back as well. Have to say I did a LOT of soul searching before I bought another GM product . There were a lot of low mileage 2ss verts on the market but I was afraid this was the reason they were low mi. Ended up buying a ex rental 2019 w/ 30k mi and saved about 18k from new . A10spd runs great . Side note /// notice I drive a Ram now?
Why not just have the fluid replaced? It is going to be a problem in every vehicle that comes out of the factory with the A8 transmission.
Side note to side note, why go with something that tends to be less reliable? Should have gone Toyota
PhantomV8 is offline   Reply With Quote
Old 06-15-2022, 06:01 PM   #17
KindaOrange
KindaOrange's Avatar
Drives: 2018 Camaro 2SS
Originally Posted by grampa_ss View Post
I have a 2016 SS, 51,000 miles. Procharged at 25K. No issues, no shudder, no rattles. Several times I've driven over 400 miles to the track, race the shit out it and drive it home. Absolutely love this car.
This is the wayyyyy my mannnn
KindaOrange is offline   Reply With Quote
Old 06-15-2022, 09:59 PM   #18
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
My A8 '17 has over 200,000 miles- trans fluid swapped out at under 50k. No issues. Had it cammed at 125000 miles. Pretty reliable car - long commutes, lots of road trips.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 06-16-2022, 06:21 AM   #19
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
wow
Camaro fanboy is offline   Reply With Quote
Old 06-16-2022, 07:39 AM   #20
YellowFever
YellowFever's Avatar
Drives: 2018 Hyper Blue SS
I've got 98,000 plus on my 18 2SS. Nothing but smiles...............and miles.
Hyper Blue 2SS - Cold Air Inductions CAI - Elite Engineering Catch Can - Black Fuel Door - GM Strut Tower Brace - GM Fender Hash Stripes - Ikon Front Lower Spoiler Lip - GM Black Bow Ties - GM Rear Deck Blackout - 35% Window Tint - GM Smoked Tail Lights & 3rd Brake Light - Range Technologies AFM Disabler - Jet Performance Stage 2 Module - Jet Performance MAF Sensor - Jet Performance Throttle Body - GM Stainless Gas & Brake Pedal Upgrade - Soler Performance TC - OE Wheels ZL1 Replicas
YellowFever is offline   Reply With Quote
Old 06-16-2022, 08:33 AM   #21
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Originally Posted by Need4Camaro View Post
For starters, test drive it. You will KNOW if it has the shudder or not. It feels like you're driving on rumble strips while lightly accelerating.
The Shudder issue applies to ALL ...not just some but ALL A8 cars, not just Camaros but ANY GM car with an A8. It's not a matter of if, it's a matter of when. Some have gone much longer than others without experiencing it but everyone with an A8 WILL eventually experience it. Its plainly a design flaw and it's also inevitable. Mine didnt come on till about 35k miles to give an idea how long it can remain silent. Others have gone shorter and others went longer. The initial fix was to do a triple flush and replace the TC if that didnt work, although neither were permanent fixes. The new fix uses a new type of fluid / additive and it's still kind of in the incubation stages but so far it seems to be holding up.
Your 65k mile DRIVRTRAIN warranty will cover any issue such as the shuffer, TC or tranny failure.
If you're plainly interested in the 16 - 18 body style and it has to be an auto, change the TC, have the TCM tuned, flush the tranny and you'll probably be 'okay'. Note this will void the warranty however.
Otherwise go for a 2020.
Hence why I bought a 2020. My 2016 had that issue, I did the triple flush and had no problems after, but when I decided to buy my current camaro, I made sure it was a 2020.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
Old 06-17-2022, 10:02 AM   #22
xmattyx
mattyv
xmattyx's Avatar
Drives: 2017 Camaro 2SS
I bought my 17 2SS a year ago with 9k miles and it had the shudder, the above TSB resolved it and hasn't come back since. I would be wary of higher mileage SS's that may not have had it done as a simple flush may not fully resolve it (just from reading other owner's experiences)
2017 Chevrolet Camaro 2SS
2017 Jeep Grand Cherokee
2015 Jeep Compass (sold)
2014 Hyundai Sonata GLS (sold)
2013 Chevrolet Camaro 2LT/RS (sold)
2013 Hyundai Genesis Coupe 2.0T (sold)
2010 Chevrolet Camaro 1LT (sold)
2007 Dodge Charger SRT-8 (sold)
2007 Cadillac CTS (sold)
2005 Chrysler Sebring (sold)
1998 Dodge Avenger (sold)
1992 Mercury Topaz (sold)
xmattyx is offline   Reply With Quote
torque converter, transmission
