10-21-2019, 02:22 PM | #1 |
Drives: 2011 Inferno Orange 2SS/RS Join Date: Jan 2012
Fix Loose rubber strip under front fascia?
The rubber strip underneath my front fascia is starting to come loose. I’ve rubbed it up against a few parking barriers that were just the right height to pull up too far but, pull on the strip when I reversed. Anyway one side has actually come loose because the tab it connected to on the fascia has sheered off. Does anyone have a recommendation on how to fix this? It seems like it would be a common problem but I’m having trouble searching because I don’t know the right terminology. I think the pics I’m attaching will explain it better than I can. Any advice would be appreciated.
10-21-2019, 02:26 PM | #2 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
You broke the bumper tab where the rubber attaches to the bumper. Outside of getting a new bumper, or just removing that piece all together, you're going to need to try and repair that tab.
10-21-2019, 02:27 PM | #3 |
10-21-2019, 02:37 PM | #4 |
Thanks. $300 to fix this seems excessive. Given that the tab is in an a non visible spot I was thinking I could bolt on a bracket of some kind.
Would this missing tab prevent me from installing a splitter and hiding the rubber strip. Or making the strip unnecessary?
10-21-2019, 05:25 PM | #5 |
The link was more to indicate that you would have to plastic weld it and not try and glue it. There are cheaper versions around. Yes you could probably bolt a bracket if you are ok with how it looks. Mine came with a splitter already, but I don't think it uses the tabs at all. Just be more careful with the parking barriers since they don't have any give to them.
11-04-2019, 01:32 PM | #6 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
it keeps road dust and debris down and out of the engine compartment. If anyone orders a new one, make sure you also order the special retainers that are sold separately.
11-04-2019, 02:09 PM | #7 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
The retainers from GM are a joke. Plastic nut and bolt for almost $9 each.
Go to Lowes and buy a box of nylon nuts and bolts for 10% the price. |
11-05-2019, 05:24 AM | #8 |
Drives: 2012 1LT Join Date: Nov 2015
The GM retainers, while expensive, protect the rubber deflector and bumper cover from tearing. If you hit something with the deflector the GM retainers will pull apart where a plastic nut and bolt will hold securely either tearing the deflector, or pulling through the plastic bumper cover costing quite a bit more than the price of the retainers to fix.
11-05-2019, 10:11 AM | #9 | |
The GM retainers loosen with vibration and fall out. Don't hit shit and you won't have to worry about damaging other parts. |
11-05-2019, 12:31 PM | #10 |
Drives: 2015 Camaro Join Date: Aug 2018
People just pull up to the sidewalk curb and have their front ends hanging over it. I see this a lot at shopping malls. To avoid this and door dings, I usually park in the back away from other cars and high curbstones and sidewalks.
One time, I pulled in where there was a curb stone and my rubber deflector was literally, I swear, one or two mere millimeters away from scrapping. I couldn't believe it. I just stood there and stared at it thinking how lucky I was from not damaging the deflector or bumper in such a close call like that. |
11-05-2019, 02:08 PM | #11 |
Great White
I removed mine about a year ago. I guess I'm just lucky cuz I've had no issues with dust or dirty engine, underside still looks new, and really haven't felt a loss of power if it had any aerodynamic purpose. I try to stay careful when parking. As Vegas said "Don't hit shit"
Worked out for me.
11-05-2019, 03:04 PM | #12 | |
11-05-2019, 06:00 PM | #13 |
11-06-2019, 09:42 AM | #14 |
Thread Tools | |
