01-29-2023, 07:45 PM | #1 |
Drives: 2019 Camaro 1SS-1LE Join Date: Apr 2019
Vorshlag 6th Gen (2016+) Camaro Camber Plates for OEM style springs
Sold, Vorshlag adjustable caster camber plates for 2016 and newer Camaro with magnaride struts and stock springs. EC. Used for approximately 2000 miles. $550 shipped. Sold
01-31-2023, 11:03 PM | #2 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
VORSHLAG tips
ALSO these are rebuildable when the time comes by replacing the top bearing and seal. If you go with a different strut set up like I did with KW CoilOvers that use the smaller than stock diameter springs VORSHLAG can change out the part that can accommodate that. I get up to -3.8 degrees camber using these. GREAT product!!!
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
02-03-2023, 08:05 AM | #3 | |
Drives: 2019 Camaro SS 1LE Join Date: Mar 2019
02-11-2023, 12:19 PM | #4 |
I tried giving you positive feedback, but I can seem to get it to post either. Not sure what I'm doing wrong. Thanks for the feedback here.
04-26-2024, 07:17 AM | #5 | |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
04-26-2024, 07:39 AM | #6 | |
No, You have to remove the strut to be able to replace the bracket. Jason at VORSHLAG is a wonderful resource to call if needed.
