Old 04-26-2024, 09:32 AM   #1
winged1
Drives: 2016 2SS Auto
2016 LT1 First Round of Mods - Questions
So I’m in the middle of adding a TSP stage 1 cam, Ls7 lifters, kooks catted long tubes, ported MSD, Ported 95mm tb. I pulled the engine out of the car to make things easier. This is on a 2016 6.2. Goal for now is 525whp. Later I will Procharger it and look at 700whp max running e85. Questions: (I know I should have done this before) but I need to pull the stock tune out of the ecu so my tuner can send me a start up tune. I will now need to plug battery back in and pull the fuel pump fuse so I can pull the file. Can someone tell me where the fuse is located? Secondly, is it remotely possible to lower the engine back in with headers already installed? Any recommendations is appreciated. Thank you.
winged1 is offline   Reply With Quote
Old 04-26-2024, 01:19 PM   #2
winged1
I forgot to mention PRC ported heads and arp head studs.
Old 04-26-2024, 01:38 PM   #3
Although I have a 2018, I hope the fuse layout is the same on your 2016. Rear fuse box, F35, see diagrams from the owner's manual below.
Old 04-26-2024, 07:36 PM   #4
winged1
Perfect thank you.
