Old 01-23-2024, 12:57 PM   #71
ZPirate
ZPirate's Avatar
Had XPEL PPF installed on the front facia, the front lip, the headlights and the part of the front fenders closest to the front facia. I have the same set up on my 1LE and it has done a great job of protecting the front of the car. I wanted to get this done before spring gets here. I had intended to do it in November, but was either too busy or couldn't get an appointment when it was convenient for me.
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 01-24-2024, 08:10 AM   #72
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
What did that run ya for price? Looking at getting mine done in the spring. Car is in storage until then
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 01-24-2024, 08:26 AM   #73
ZPirate
ZPirate's Avatar
It was basically a grand for all of it. Well worth the cost in my opinion though.
Old 01-24-2024, 12:43 PM   #74
split_bumper
That is reasonable. I have been shopping around for quotes. May have to just drive the car further south to people that will do it for a reasonable price. I have 2 guys that are reliable and have done friends stuff for around 1500 for what you mentioned. Most here are 1800-2500. Full front end, with hood and full fenders, mirror caps, skirts, rear part in front of rear tire, was quoted 3500-4000 for that. I just can't justify that much, i'll take my chances and get it painted in the future if I really have to
Old 01-24-2024, 01:49 PM   #75
ZPirate
ZPirate's Avatar
Yeah $1,500 plus sounds like quite a bit for what I had done. I didn't do the mirror caps on my car since I have covers on them. I also didn't do the hood. The hood would have been another $800. The front facia on the Camaro comes up high enough that the hood is less likely to get rock chips. I have ACS rock guards too, so I didn't have the fenders or the side skirts wrapped.
Old 02-27-2024, 04:49 PM   #76
ZPirate
ZPirate's Avatar
Over the weekend I went to visit a friend of mine in a nearby town who recently purchased a Mustang Dark Horse. It actually looks larger than the ZL1. Both cars are white so kind of cool seeing them side by side. The Dark Horse is very expensive for what it is though.
Old 02-27-2024, 05:11 PM   #77
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I've always wondered what the Mustang could have been if they stayed with pushrods
Old 02-28-2024, 11:08 AM   #78
paradigm
Drives: 2022 Camaro 1SS 1LE
Attachment 1147144
Attachment 1147145
The Dark Horse is more an SS 1LE competitor, and way overpriced for what it is. Cool photos though.
2022 Camaro 1SS 1LE 6-speed
paradigm is offline   Reply With Quote
Old 02-28-2024, 12:52 PM   #79
ZPirate
ZPirate's Avatar
Very true. Unfortunately the Dark Horse is priced more like a ZL1 than a 1LE.
Old 04-18-2024, 12:30 PM   #80
ZPirate
ZPirate's Avatar
Installed an LSA Conversion LT4 supercharger reservoir upgrade kit (version 2) and a BMR Suspension strut tower brace.
The supercharger reservoir adds extra coolant capacity to the system and makes it easier to add coolant and bleed air out of the system. It also looks OEM since it uses a GM coolant reservoir. Its the first kit of this type I've seen that actually looks like it came on the car.
The BMR Suspension strut bar is well made and is one of the few Gen6 Camaro strut bars I've seen that will fit over the factory supercharger. It's not cheap, but is a quality piece.
Two pretty good mods. Here are a few pictures.
Old 04-20-2024, 01:41 PM   #81
ZPirate
ZPirate's Avatar
My two Zs. Different manufacturers and 20 years difference in ages, but nonetheless both Zs.
Old 04-26-2024, 06:48 PM   #82
ZPirate
ZPirate's Avatar
I've been trying to decide whether I wanted to add a cold air intake. I was close to purchasing a Rotofab intake, but after doing more research I decided on a Green Filter in the stock airbox. I found comments/videos from several people who track their ZL1s who were of the opinion that the Rotofab intake was subject to heatsoak, especially when the ambient temperature is above 80 degrees (which it is here for about half the year). The Green Filter in the stock airbox on the other hand tended to produce lower intake temperatures (IATs).
As someone who has tracked IATs with my ScanGuage for years I didn't want an intake that would increase IATs. Even though the Rotofab seals to the hood, it isn't completely sealed from the engine bay like the stock airbox is. And the partial box of the Rotofab is metal which tends to hold heat more than plastic does.
Old 04-29-2024, 08:57 AM   #83
ZPirate
ZPirate's Avatar
In my continuing effort to keep my intake temps (IATs) in check now that we are approaching summer weather here in eastern NC, I removed the steel sound plate from inside the supercharger lid. Removing the SC lid is not that difficult, except for the 20 10mm bolts that you have to remove in order to get it off.
Removing the steel plate does increase the whine from the SC some, but that's not a bad thing. I get why GM installed the plate to try to keep NVH in check, but putting a steel plate inside of an aluminum SC cover only serves to increase heat inside the lid.
The combination of my new Green air filter (in the stock airbox), removing the steel plate from the SC lid and adding a separate reservoir for the SC coolant has helped keep my IATs at ambient. Before doing these my IATs would run a few degrees over ambient. Hopefully this trend will continue as the temps rise this summer.
Old 04-29-2024, 11:07 AM   #84
ZPirate
ZPirate's Avatar
Here are pictures of the underside of the supercharger lid and the steel sound plate that I removed.
