05-06-2024, 08:53 AM | #1 |
Drives: Rs 2011 Join Date: Jul 2017
2011 Chevy Camaro help needed !!
😢 hey guys
3 days ago I encounter a problem I was spilling gasoline , because my fuel line rapture not sure how. I’ve been looking for the part, haven’t been easy , I check with the dealer they said it’s discontinued. Or I can take it to a modified place see if they can do something else. (Geeee) One place told me shipping will take about a 2 month June 24 Hoping you guys can help me located a faster or another solution . Only way to get to work . I’m starting to think that I may need to work some more hours to try to get an second car. Thanks 🙏 . 5/9 Inch I.D. 17-7/16 Inch Long Plastic Fuel Feed Line - |
05-06-2024, 09:07 AM | #2 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
05-06-2024, 09:15 AM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
You can also build it with some nylon fuel line, but it takes a good bit of patience. You can get the bends done with a heat gun or boiling water. Boiling water is the safer but more difficult option. You have to over bend the curves a bit because they will relax once they cool.
If the rupture is not too close to a fitting, you can patch it with some fuel line and hose clamps. Otherwise, look for a salvaged car.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-06-2024, 04:19 PM | #4 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Where exactly is it leaking in that pic? At our shop we have a nylon fuel line repair kit with different type/style connectors/unions etc....3/8 and 5/16 line. A shop in your area has gotta have a repair kit like we have here. GL
05-06-2024, 04:56 PM | #5 |
Thank you guys for the advice, I will take heed , I know I can’t do it ..
If someone in here can , we can discuss donation. lol ( I’m serious) 😩 Below I found this on a website Do you guys think this will work fine ? I will call a few salvage place and see how for I can get |
05-07-2024, 08:48 AM | #6 |
