Old 12-11-2014, 08:38 AM   #1
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
Pegasus Solid Aluminium Subframe Bushings
We are pleased to have in stock out newly designed solid subframe bushing sets. We decided to apply our aircraft experience into these bushings, using through-hole drilling to achieve a 10% lighter (per set) design than previously offered anywhere near our price point, which cannot be beat by any other solid subframe bushing!
Using USA-made 6061-T6 Aluminum, we machined these in-house on our CNC turning center, and anodized them black. Our through-hole drilling is enabled through our ability to drill off-axis during the machining operation, resulting in reduced machining time, resulting in cost savings that we are passing on to you! If you have ever been on the fence about buying solid subframe bushings, but have been scared off by the price, just contact me directly, or purchase from our website!
If there are any technical questions, please feel free to ask!!!
2012LS3VERT is offline   Reply With Quote
Old 12-11-2014, 09:53 AM   #2
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
Just installed your "Pfadt" style bushing, they are boss. I wish I would have seen you were coming out with these ones. They look much nicer
krusher is offline   Reply With Quote
Old 12-11-2014, 10:04 AM   #3
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Please PM me shipped price to 22046
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-11-2014, 10:26 AM   #4
2012LS3VERT
We kept it under wraps, sorry. We try to do good business, and we tried to wait as long as we could to allow all of the ones we made previously to sell, as not to step on any toes. The same goes with the trailing arms and toe rods we are making, we aren't making any more after this run, since we used the previous design. We are going to do a new design, but we already ordered the material, so we have to sell what we have.
Old 12-12-2014, 01:22 PM   #5
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
I like the price on those subframe bushings
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 12-12-2014, 01:41 PM   #6
2012LS3VERT
Thanks everybody for the inquiries and orders! I guess we should have made more than 10 sets! We will be out soon. We usually pride ourselves on quick production times, but with the holidays it may be after the first of the year before we have any more, so if anyone wants any, just request a price here or by PM and I'll shoot you the best deal around! They can also be seen on our website. These made a HUGE difference on my car, and I switched from stock to poly to aluminum, and was by far the best upgrade I made, even better than the trailing arms and toe rods, or camber plates. The rear of the car is so much more predictable now, it greatly increased my confidence in the corners.
Old 12-12-2014, 03:26 PM   #7
ROD_SS
ROD_SS's Avatar
How long did it take for you to install these?
Old 12-12-2014, 03:30 PM   #8
2012LS3VERT
I do a full cradle pull in 3 hours, but I have a lift. Most say it can be done in 3 or less doing the lower cradle/heat/jack up method. Removal is the hard part, new ones slide right in.
Old 12-12-2014, 03:41 PM   #9
ROD_SS
ROD_SS's Avatar
I was there when a buddy was doing his. Like you said , he was doing the heat up method. Finding a lift is easy but I'm just thinking of how to remove them if no heat is present.
Old 12-12-2014, 04:10 PM   #10
2012LS3VERT
I use a Sawzall with a long blade from the inside out, with the cradle on the ground. But for heat, a cheap propane torch kit from the hardware store will do it.
Old 12-12-2014, 05:29 PM   #11
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Thanks Brotha for the bushings! Cant wait to get these and get them installed!!!!
Nighthawk89 is offline   Reply With Quote
Old 12-12-2014, 06:44 PM   #12
2012LS3VERT
No problem, they will go out first thing Monday with the other sets that were ordered today.
Old 12-13-2014, 09:30 AM   #13
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Price? Pm me! Thanks!
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 12-13-2014, 10:46 PM   #14
RJT2SSRS
RJT2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
I would also like a price to 48173.
2010 2SS/RS L99 CAI intake Stainless Works headers and Hi-flow cats CORSA cat back exhaust livernois motorsports dyno tune VMAX throttle body ELITE catch can GM clean side catch can 2014 lca BMR rear toe links PEDDERS Supercar suspension PEDDERS poly subframe bushings JPSS BLACK MAGIC rear sway bar DSS 1000 hp axles 1LE wheels Michelin 285/35 tires CTS-V front brake upgrade fuel rail flip heater hose relocation
RJT2SSRS is offline   Reply With Quote
