Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Past Camaro Fests > 2015 Camaro Fest (VI)
Old 12-08-2014, 02:54 PM   #1
Merc
In The Circle
Merc's Avatar
Camaro Fest VI - Drag Racing (Beech Bend Raceway)
Main 5th Gen Classes
BRACKET RACING: Any Make/Model. (Vette's, CTS other makes and models, 1st to 4th Gens as well.)
ALL V6: Any V6 5th-gen Camaro
STOCK V8: Any V8 5th-gen Camaro. CAI and/or Catback only, are allowed. No Headers, tune, engine modifications. (Street tires will consist of OE radials or any DOT street compound radial, regardless of size. Tire must have a 200+ treadwear rating to fit into this class)
MODIFIED: Any naturally-aspirated street-licensed 5th-gen Camaro (No nitrous)
SUPER-MODIFIED: Any force-inducted IRS 5th-gen Camaro. Unlimited mods, (18" rear wheels or larger ).
UNLIMITED: Any force-inducted IRS 5th-gen Camaro. Unlimited modifications. Any driver.
*** In addition to Brackets you may only enter one of the main classes and will be tech'd accordingly
Extra Classes:
M6 STREET TIRES: Any manual trans 5th-gen Camaro on street tires. (Street tires will consist of OE radials or any DOT street compound radial, regardless of size. Tire must have a 200+ treadwear rating to fit into this category.)
ZL1 UNLIMITED: Any ZL1 Camaro
RESULTS
Name:  Drag Finals.jpg
Old 12-08-2014, 02:54 PM   #2
Safety Rules for Drag and CamaroCross
Helmets required for all racing events ( Exception: Drag Racing slower than 13.99 does not require a helmet.
Equipment and Tech for CamaroCross
  1. Helmets are Required, if you don't have one try to borrow one. Snell 2005 2010 SA OR M rated helmets are required. Bring your own helmet or make arrangements to share one. There may be one or two loaner helmets at the CamaroCross course. If you have spare helmets and are willing to share please bring it. If you have access to a batch of SCCA rental helmets please let us know![/B]
  2. Your Camaro must be empty. If it isn't bolted down it shouldn't be in the car.
  3. No drivers side floor mats are allowed.
  4. No drips or leaks are acceptable.
  5. Your battery and every thing under the hood and in the trunk must be bolted down securely.
  6. Your tires will have to pass the Lincoln test, unless they are slicks.
Autocross Staffing
We have NO SCCA support for the event. To make the event run smoothly we need Camaro5 member help.
ALL drivers will be expected to work corners when their group is not running
Drag Racing
There are two primary objectives for Drag Racing.
#1 SAFETY
#2 FUN
Here are a few things you may not think are important for the Drags, but...
Sun Screen
Hydration -- Lots of WATER
Friends
Snacks
Water
Water
Water
PROTECTIVE CLOTHING
Full-length pants; short- or long-sleeved shirt; closed shoes; and
socks. No shorts. No tank tops. No open-toe or open-heel shoes or
sandals. Synthetic clothing not recommended. Jacket and pants
meeting SFI Spec 3.2A/1 mandatory in AA/S through M/S, AA/SA
through M/SA, and in any vehicle running 11.49 or quicker. SFI
Spec 3.3/1 gloves mandatory in any vehicle running 9.99 or quicker.
See General Regulations 10:10.
HELMET
For all 10.00 and slower cars, either an open-face or a full-face
Snell M2005, M2010, K2005, SA2000, SA2005, SA2010,
SFI 31.2A, or 41.2A helmet mandatory; shield permitted (goggles
prohibited).
For all 9.99 and quicker cars, a full-face Snell M2005,
M2010, K2005, SA2000, SA2005, SA2010, SFI 31.2A, or 41.2A
helmet mandatory; shield permitted (goggles prohibited). See
General Regulations 10:7.
The NHRA 2012 Rule Book Reads as follows for Helmets and Goggles:
As outlined under Class Requirements, drivers in all classes, including motorcycles, must wear a helmet meeting Snell or SFI Specifications.
SFI Spec 31.1A = Snell SA, open-face helmet
SFI Spec 31.2A = Snell SA, full-face helmet
SFI Spec 41.1A = Snell M, open-face helmet
SFI Spec 41.2A = Snell M , full-face helmet
Effective Jan. 1, 2008, full face helmet mandatory on all cars 9.99 or quicker. See Individual Class Requirements for additional requirements. Shield mandatory 7.49 & quicker.
E.T. cars (13.99 or quicker) must use a helmet meeting Snell 2005, 2007 or SFI 31.1A, 31.2A, 31.1/2005, 41.1A, 41.2A or 41.1/2005 Specs. Drivers in supercharged, front-engine, open-bodied cars and Funny Cars must wear a helmet meeting Snell SA2005 or SFI 31.1A, 31.2A, or 31.1/2005 Specs. See Class Requirements.
Modifications to helmet/shield are prohibited. All helmets must have the appropriate certification sticker affixed inside the helmet.
ALL POWER ADDER RACERS WITH N0N-OEM/FACTORY POWER ADDERS IE:SUPERCHARGERS,TURBOCHARGERS,OR THE USE OF NITROUS. SECTION 1A,PAGE 65 OF THE 2009 NHRA RULEBOOK READS AS FOLLOWS. "10.00(*6.40 1/8 MILE) AND SLOWER; ALL E.T.NON-OEM SUPERCHARGER,NON-OEM TURBOCHARGED, OR NITROUS-EQUIPPED CARS WITH AN OEM OR .024-INCH STEEL FIREWALL: JACKET MEETING SFI SPEC 3.2A/1 MANDATORY. "
NECK COLLAR
Neck collar meeting SFI Spec 3.3 mandatory in any vehicle running
9.99 or quicker or exceeding 135 mph. A head and neck
restraint device/system may be used in lieu of a neck collar. See
General Regulations 10:8.
ROLL BARS
Roll bar mandatory in all cars (including T-tops) running 11.00 to 11.49
in convertibles running 11.00 to 13.49
ROLL CAGE
Roll cage mandatory in cars running 10.99 or quicker or any
car exceeding 135 mph. In full-bodied cars, with unaltered firewall,
floor, and body (from firewall rearward, wheel tubs permitted),
running between 10.00 and 10.99, roll bar permitted
in place of roll cage. In convertibles running 10.99 or quicker or
exceeding 135 mph, roll cage mandatory. Cars running between
7.50 and 9.99 must have chassis re-certified every
three years by NHRA and have a serialized sticker affixed to cage
before participation. Plating of chassis prohibited for all cars
manufactured after Jan. 1, 2003. Rear-engine dragsters must
conform to SFI Spec 2.7B; vehicles running 8.49 to 7.50
and/or exceeding 180 mph must meet appropriate SFI Spec
for body used. Effective Jan. 1, 2007, all new Street Roadsters must
conform to SFI Spec 10.4. Existing Street Roadsters must meet SFI
Spec 10.4 at their next scheduled re-certification effective Jan. 1,
2008. No existing cars will be re-certified early to delay compliance.
All others must conform to specs for body style used, as listed in
General Regulations 4:11, 10:6.ET.
ROLL-CAGE PADDING
Roll-cage padding meeting SFI Spec 45.1 mandatory on any
vehicle running 9.99 and quicker. Padding must be used anywhere
driver’s helmet may come in contact with roll-cage components.
See General Regulations 4:11, 10:6.
PARACHUTE
Mandatory on any car that runs 150 mph or faster. See General
Regulations 4:8.
Old 03-06-2015, 12:42 PM   #3
Merc
In The Circle
Merc's Avatar
Here you go folk's these are the Drag Racing classes for Fest in Bowling Green.
Old 03-06-2015, 12:46 PM   #4
RubyCamaro
Jan
RubyCamaro's Avatar
I will be running brackets & V6! Can't wait!
Old 03-06-2015, 01:09 PM   #5
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Ditto!
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 03-06-2015, 02:24 PM   #6
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
M6 street tire class needs a minimum tread wear too.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 03-06-2015, 02:39 PM   #7
Merc
In The Circle
Merc's Avatar
Done. Same specs as the Street Tire 60' list requirements.
Old 03-06-2015, 02:44 PM   #8
Ace0751
GEN5 Detail
Ace0751's Avatar
Drives: 2011 Synergy Series 2SS Convertible
I'll probably be in the stock V8 or modified. But for now stock V8
Roto-Fab CAI, Borla ATAK Exhaust System, Stainless Power Headers, RX Performance Catch Can, ACS T4 Splitter, Oracle side markers, Dyno Tuned by RDP Motorsports
Ace0751 is offline   Reply With Quote
Old 03-06-2015, 05:24 PM   #9
You can do bracket racing as well.
Old 03-06-2015, 05:26 PM   #10
ntmad8tr
Music City Camaro Club
ntmad8tr's Avatar
Drives: 2014 2SS/RS Spring Special Edition
Looks like brackets and modified for me.
EMC(SS) USN RET. 2014 2SS Spring Special Edition,1 of 293. Cold Air Inc. CAI,Apex Catch Can, Kooks 1-7/8" headers, Kooks HF Cats, X-pipe, Kooks mufflers,Graphite, BMR Toe links, BMR rear trailing arms, MRR228s,RGB ORACLE Colorshift Halos, RGB LED Engine bay and Grille lighting, Diode Dynamics RGB Fog Lights. NightOwl LED control system. Painted engine cover by S.L. Customs. River Cities Creations painted strut brace. My Build Thread
ntmad8tr is offline   Reply With Quote
Old 03-06-2015, 05:38 PM   #11
racergirl
racergirl's Avatar
Drives: 2014 Red Hot 2SS/RS A6 Camaro
I gotta say something. Don't wanna be the jerk but someone has to be. Can we please break up the V6 class? How is it fair for me, a car with a CAI only, going up against a force inducted car? It's not fair in the slightest
Current Camaro: 2014 2SS
Performance Mods: BBK Headers, Borla S type axle back, tune, TSP Stage 1 cam, Vararam Intake, DR's
11.77 @ 119.21
Former Camaro: 2013 2LS
BONE STOCK: 13.953@100.77 With Bolt-Ons: 13.646@101.60
With 75 shot and Bolt-Ons: 12.587@111.25
Performance Mods: CAI Intake, MRT V2, SLP Underdrive Pulley, DRs, Skinnies, Rear seat delete
racergirl is offline   Reply With Quote
Old 03-06-2015, 05:41 PM   #12
We've tried that twice before. If we have enough cars we will... but will have to wait and see if that happens. Track time decision for this one.
This is the exact setup as last year and I don't believe we had a single V6 FI car.
Old 03-06-2015, 05:44 PM   #13
Ace0751
GEN5 Detail
Ace0751's Avatar
And that to of course
Old 03-06-2015, 05:47 PM   #14
Just want to make sure you are busy..
