04-07-2023, 02:34 PM | #1 |
Drives: Chevrolet Camaro SS Join Date: Dec 2021
Best Intake For Street/Strip
I am currently in the process of intake shopping. I am looking for something that is good for street/strip applications that doesn’t sacrifice torque for high end power. I currently have long tube headers, full exhaust, BTR cam valve lift 631 int. .617 exh, duration 233 int. 250 exh, 113 lobe sep., BTR valve springs 660” lift dual platinum, 650 cc injectors, BBK 102mm TB, Roto-Fab cod air kit and stock intake. I am making 475 RWHP, 452 TQ on E85. Looking to try and get 500 RWHP or as close as possible. With so many intakes out there, I am trying to reach out for those that have real world experience aftermarket units. TIA.
04-08-2023, 06:54 AM | #2 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I am very Happy with my GPI Ported Rod Mod, It was a very noticeable difference.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
04-08-2023, 09:40 AM | #3 |
^^^^^ This will be your best bet!! Lots of guys using this one. If you want 500 wheel, you should do a head swap. That'll get you there, or very close to it. Good luck. I'm happy with my 486 wheel..
04-09-2023, 10:38 AM | #4 |
Does the GPI ported rod mod intake have a 102 mm TB opening?
04-09-2023, 11:57 AM | #5 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
04-09-2023, 12:42 PM | #6 |
I run a BO White ported TB on mine, I do believe you can open it up to accept a 102.
04-09-2023, 10:46 PM | #7 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
If I remember correctly they didn't have good results with opening the factory intake to 102mm and it definitely didn't help anything. I have the fast lsxr 102mm and you can get it with the race runners inside that will move the peak hp up quite a bit but it's definitely pricey.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-10-2023, 03:00 PM | #8 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Ported stock TB and stock manifold unless your cam needed valve reliefs flycut into the pistons.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
04-14-2023, 06:27 AM | #9 |
Drives: 13' 1LE Join Date: Apr 2012
I have a custom high ram Goertz1 that fits under the hood. I dont notice any dip in TQ or drivability problem. If you do some mileage, stock with rod mod is efficient.
I had a TSP stage 3 cam only back then with the Goertz1 high ram and that combo was very efficient.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-14-2023, 08:51 AM | #10 | |
04-17-2023, 09:27 AM | #11 |
I have the LOD X-1 manifold on mine with the TSP Stage 3 cam and it plays very well together. Very streetable and good cruising on the interstate too. Fits under the stock hood with NO cutting of anything. But I'm not sure if you can get one anymore. Numbers in my sig. V-MAX ported TB.
