10-31-2020, 05:32 PM | #85 |
Drives: '22 Camaro SS 6.2 A10 Join Date: Sep 2020
What is the price on the big wheel turbo?
10-31-2020, 05:46 PM | #86 | |
Also, is there an issue with having a larger TB? Last edited by DexnBlair; 10-31-2020 at 06:17 PM. |
11-11-2020, 08:03 AM | #87 | |
Drives: Chevy Camaro and Corvette C6 Join Date: Nov 2020
11-12-2020, 10:01 PM | #88 |
11-15-2020, 08:26 PM | #89 | |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Ebay PLM brand seems to be solid on a catless..Catless will continue to become harder to get as time passes.. Along with MANY automotive staples... Skip the TB... You will not exceed 600WHP...
11-16-2020, 05:51 PM | #90 | |
I emailed ZZP and they said they stopped making the catless downpipe. I haven't even seen PLM listed on ebay, I just stumbled on their website trying to find a catless downpipe. |
11-18-2020, 03:08 PM | #91 | |
Coopers Camaro
https://privatelabelmfg.com/products...ABEgK0qPD_BwE#
11-19-2020, 08:20 AM | #92 |
Drives: 2020 Chevy Camaro Join Date: Oct 2019
one thing that sucks with this downpipe though is you have to fabricate your own gaskets as it won't reuse the factory type gaskets like the more expensive brands. The flange on the back side was also a little crooked because of the welding so i had to buff it out to make it straight so it would seal and not have a leak.
11-19-2020, 08:41 AM | #93 |
Drives: 18 Camaro LS M6 Join Date: Apr 2019
in case you didn't know there is a huge black market for catalytic converters. seems the source metals are spiking in price. be sure to retain your original. ZZP probably got hit with an EPA cease order.
. . NFG M6 2T Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel Last PB 4.8, 13.2@106 |
12-01-2020, 07:28 PM | #94 |
OK, getting excited.
The ZZP catted downpipe and throttle body spacer showed up today. More parts coming this week. Here We Go! |
12-02-2020, 06:49 PM | #95 |
12-04-2020, 05:50 PM | #96 |
12-04-2020, 07:09 PM | #97 |
Drives: 2016 Camaro 1LT 2.0t A8 Join Date: Sep 2019
Did you or will you build your engine (Rods, pistons, cams, valve springs, head studs)? I was looking at doing a turbo upgrade myself but everything I've read says a turbo upgrade with everything else I already have would push my engine internals beyond their limit.
Current mods: GM performance catback exhaust - JMS PEDALMAX throttle controller - K&N Drop In Air Filter - ZZP Intake Tube - ZZP catted downpipe - ZZP Larger (67mm) throttle body - BNR recirculator valve - Mishimoto intercooler pipes - Mishimoto intercooler - PTP turbo blanket - ZZP flex fuel kit - ZZP big wheel turbo - RX billet stall converter
Flex fuel tuned by ZZP Tires: Firestone Firehawk Indy 500 245/40/20 Pirelli Winter Sottozero Serie II RunonFlat 245/50/18 |
12-05-2020, 08:19 AM | #98 | |
