07-24-2021, 01:39 PM | #2633 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
I saw your post about the B&M Deep trans pan for the 6L80. Im thinking about doing it, but concerned about the filter not staying in. IS there a special filter needed or just the wide mouth truck filter? Also, The XA Coilovers over 1le suspension. Was it worth it? Im on stock 2011 FE2 i believe with some BMR parts. Debating the coilovers.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp Last edited by Leo72793; 07-24-2021 at 04:03 PM. |
07-27-2021, 12:58 PM | #2634 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
no issues - works great...
first page of my build has a link to the install/filter. I liked the 1le setup but if you like to race alot, coilovers are great... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 07-29-2021 at 06:47 PM. |
08-15-2021, 11:36 PM | #2635 | |
Drives: Chevy Camaro ZL1 Join Date: Feb 2019
CAVEAT: Be certain the engine is cold before attempting the test or the computer will balk. Many thanks there Hammdo! |
08-17-2021, 08:20 PM | #2636 |
Anytime! The caddy option is a good one to use too...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
08-26-2021, 10:11 PM | #2637 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I asked my father why he tasted the whiskey one day and declared it was low in alcohol, it didn't make sense to me. He put marks on the bottles because the babysitters would drink the booze. If it was below the marks when the parents returned home the babysitter was boozing. The sitters wised up and started to fill back up the bottles to the lines with tap water so it looked like they didn't drink any. Eventually it would taste watered down. When I would unauthorized borrow the fathers vehicle he wouldn't notice higher mileage but would remember where the gas gauge needle was. Like the lines on the bottle, if I refilled it back to where it was I got away with it. The babysitter had no idea the 7-11 gas would show up as watered down alcohol in your car! |
09-23-2021, 12:02 PM | #2638 | |
Rear Bellypan
Don, Just curious how you mounted the rear bellypan especially in the front, I’m working this project myself now.
Orange Krush II
09-25-2021, 06:15 PM | #2639 |
I'll see if I can get a pic of the front mounting. I believed I used the trunk support and SS sheet screws....
-Don
747 RWHP 794 RWTQ
03-25-2022, 08:51 PM | #2640 |
It's been a while so quick update:
She's running fine - finally had to replace my Duracell AGM battery after 7 years - almost to the day I bought it! Have been enjoying the Mooney... Just some pics from our trip to Hot Springs AR: -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 08-21-2022 at 05:09 PM. |
03-26-2022, 05:49 AM | #2641 |
Looking good Don & hope Hot Springs was good to ya! Im surprised you haven't started a LSA swap for the Mooney...Ha!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
03-26-2022, 11:26 AM | #2642 |
Um, I would if I could! Probably turbo though ;o)
Right now, just enjoying life... -Don
747 RWHP 794 RWTQ
04-05-2022, 01:49 AM | #2643 |
Boosted Moderator
When I worked in the Kerrville FD, as part of the pre-fire plan, we toured the entire Mooney plant… It was amazing how much of the aircraft was built on site, from the frame to upholstery… Basically everything except the engines and electronics…
They built comfortable workhorse aircraft… I’ve flown in a few and enjoyed every minute…
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
04-08-2022, 05:20 PM | #2644 |
-Don
747 RWHP 794 RWTQ
05-13-2022, 11:23 AM | #2645 |
Drives: 2015 Camaro 2SS 1LE Join Date: May 2022
do you still have your camaro?
05-14-2022, 08:02 PM | #2646 |
Yep!
-Don
747 RWHP 794 RWTQ
