TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 01-18-2010, 02:59 PM   #1
racergirl
racergirl's Avatar
Drives: 2014 Red Hot 2SS/RS A6 Camaro
Arrow
V6 1/4 mile Fast Thread
Rules:
In proposing submissions for inclusion on the list, please follow these simple rules or your submission will NOT be considered.
#1. Post the details of your quarter-mile pass using this template: (cut and paste)
Tires used on the pass:
Performance Mods (if any):
Transmission:
Category submitted for:
R/T..........
60'.............
330'...........
660'...........
660’ mph...
1000'..........
1320'..........
1320’ mph…
Name of the track:
Date of pass:
Weather conditions (include Density Altitude, if known - DA can be calculated by going to http://www.dragtimes.com/da-density-...lculator.php):
#2. Times that may qualify for the top-10 in each category require posting of an image of the time slip. If you lack the ability to post an image, ask for help.
#3. Track times will not be corrected for weather or track altitude. Those elements can be noted in the comment portion of the submission to clarify the conditions under which the run was made.
#4. All members are invited to submit his/her times on this thread. The top 10 or so for each category will be included in the Fast List. Only one pass per member will be included on the Fast List.
#5. In the event two members submit an ET identical to the hundredth of a second, the tiebreaker is the higher mph. In the event that this is still a tie, the tiebreaker will fall to 60' time.
#6. Any type of weight reduction that is not mod performance related (i.e. seat deletes, removal of spare tire) MUST be included.
***** Rule #2. "time slip" means full time slip. Must include date/time of the pass and customarily includes identification of the track issuing the slip.
****** Only exception is TORN TIME SLIP DUE TO FAULT OF THE TRACK.
The lists are:
1) Bone Stock (including stock tires)
2) Stock (entirely stock except tires)
NO INTERNAL ENGINE MODS
3) Bolt Ons
4) Power Adders (superchargers, and turbo chargers)
5) Power Adders (nitrous)
6) Bolt-ons
7) Power Adders (superchargers, and turbo chargers)
8) Top 10 Fastest V6 Camaros
Additionally: for the Bone Stock list, only each poster's fastest time will be included in the list. For all other lists, any run made using a different combination of modifications will be included as long as it ranks among the top times.
Please try to avoid extra discussion in this thread.
Current Camaro: 2014 2SS
Performance Mods: BBK Headers, Borla S type axle back, tune, TSP Stage 1 cam, Vararam Intake, DR's
11.77 @ 119.21
Former Camaro: 2013 2LS
BONE STOCK: 13.953@100.77 With Bolt-Ons: 13.646@101.60
With 75 shot and Bolt-Ons: 12.587@111.25
Performance Mods: CAI Intake, MRT V2, SLP Underdrive Pulley, DRs, Skinnies, Rear seat delete
racergirl is offline   Reply With Quote
Old 01-18-2010, 03:00 PM   #2
racergirl
racergirl's Avatar
Bone Stock (No internal or external engine modifications, stock tires)
1. 13.953 @ 100.77 - (2.083/60') racergirl - 2LS A6 (LFX) 11/24/2013 DA -700 Post # 1931
2. 14.247 @ ???? - (2.158/60') DandD - LS A6 (LLT) 11/5/2011 DA 95
3. 14.300 @ 98.01 - (2.127/60') etmx183 - 2LT (LFX)
4. 14.332@ 93.74 – (2.134/60’) Atlantis -2LS A6 (LFX) 11/10/2019 DA -14ft
5. 14.334 @ 98.70 - (2.206/60') KG Rockville M6 (LFX) 10/13/2012
6. 14.370 @ 96.64 - (2.013/60') DarkneSS - 1/LT RS M6 (LLT) 5/1/2011
7. 14.408 @ 94.24 - (2.109/60') Wikedwil - LS A6 (LLT)
8. 14.439 @ 97.96 - (2.154/60') jls - LT M6 (LFX) 9/12/2014
9. 14.440 @ 95.51 - (2.012/60') HDRS - LS M6 (LLT) 12/4/2010 DA -1361
10. 14.530 @ 97.29 - (2.181/60') RacnJsn95 - 1LT A6 (LFX) 4/12/2014 DA 2697
Honorary Mention:
14.656 @ 96.68 - (2.201/60') Sycraft - LS M6 (LFX) 8/17/2012
THANK - YOU goes out to racergirl for gathering the information provided showing the 60' times, date of pass, and DA (if known). Thank - you for taking the time to get all this together to further enhance our lists.
Stock (No internal or external engine modifications, any tires including drag radials):
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.77 @ 119.21
Old 01-18-2010, 03:01 PM   #3
racergirl
racergirl's Avatar
Bolt Ons (Modified airway, exhaust, tires, tune - no internal engine or power adders):
1.12.982 @ 103.74- (1.831/60’) BARRY BROOKS- A6 (K&N Filter, SS Exhaust, 3.91 Gears, Circle D converter, E85 tune on HP Tuners based off an Overkill base tune, MT 27x4.5/17 skinnies, Nitto G2 555 275/50/17 DRs, passenger seat delete) (LFX) Post#2666
2. 13.037 @ 106.23 - (1.865/60') etmx183 - A6 - (CAI intake, E85 RX catch can, Circle D converter multi disc billet, 80mm Throttle body, APEX air scoop, SOLO HFCs, JacFab ported manifold and upper intake isolator, Solo cat back Mach X system, 3.91 gears, 1 piece DSS driveshaft, Weld RT-S M&H drag radials) (LFX) Post #2575
3. 13.139 @ 105.14 - (1.809/60') Twin Town Terror- A6- (Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, ARH catless downpipes, Magnaflow cat back exhaust, Weld RT-S 17x5 f and 17x 9 r wheels, MT 28/6/17 f and M&H 275/50/17 r tires, Circle D converter, TTT rear seat delete & lightened spare tire cover, JEGS racing seats, Overkill tune, Sunoco E85R fuel) (LFX) post #2649
4. 13.420 @ 103.22 - (1.950/60') ROD1 - A6 - (Hoosier slicks & Caddy spares, Injen, ARH Longtubes/High Flow Cats, SS Axle Back, Trifecta Tune) (LLT)
5. 13.453 @ 101.9 - (1.936/60') 67 GTO - A6 - (Hoosier slicks & Caddy spares, Vararam, JBA shorties, GMPP exhaust, VMax Ported TB, SLP Pulley, Hypertech Tune) (LLT)
6. 13.466 @ 101.22 - (1.894/60') RetroRallySport - A6 - (v max, t/b jacfab intake and spacer, underdrive pulley, solo cats, magnaflow exh, zl1 pump, fti 3200 convertor, 3.91 gear, weld rts wheels, m&h racemaster tires) (LFX)
7. 13.51@100.8 - (1.942/60') usa1camaro1969 - M6 - (E85, DRs/Skinnies, Vararam, BBK Headers/High Flow Cats, Cherry Bomb V8 Cat Back, VMax Ported TB, Trifecta Tune) (LLT)
8. 13.544 @ 100.89 - (1.946/60') HDRS - A6 - (DRs/Skinnies, Injen, MRT 2.0) (LLT)
9. 13.564 @ 102.51 - (2.015/60') kjkjr27 - A6 - (DR's/Skinnies, Rotofab CAI w/scoop, BBK Headers w/HFC, 2.5" midpipe, MRT 2.0, VMax Ported TB, ported IM, Plenum Spacer, Trifecta Tune) (LLT)
10. 13.569 @ 104.07 - (2.181/60') bmorecam - M6 - (E85 tune, Vararam, OBX Headers, Magnaflow Res. X-Pipe, flowmaster exhaust) (LLT)
Honorary Mention
13.641 @ 102.28 - (1.956/60') Glasstop2010RS (DR's/skinnies, Injen, Long tube headers/high flow cats) (LLT)
13.646 @ 101.60 - (2.047/60') racergirl - A6 - (Stock BFG's, CAI, MRT 2.0, SLP under drive pulley) (LFX) post # 2447
13.659 @ 102.53 - (2.164/60') J_Vibe92 - A6 - (Stock 19's, Vararam, OBX Headers, MRT 2.0, Vmax Ported TB & Black Ice-Olator, LMR Custom Dyno Tune--Trifecta Suite) (LLT)
13.664 @ 100.88 - (1.936/60') rtcat600man -A6 - (DR's, Injen, OBX Headers, Magnaflow Res. X-Pipe, MRT 2.0, V Max Ported TB & Black Ice-Olator, RX Ported Intake Manifold & Plenum Spacer, Trifecta Tune) (LLT)
13.713 @ 102.26 - (2.005/60') formare - A6 - (Injen, SLP Catback, Solo Mach X) (LLT)
13.738 @ 99.89 - (1.988/60') BloodUSMC -A6 - (Roto Fab, OBX Headers, Magnaflow Res. X-Pipe, MRT 1.0, Trifecta Tune) (LLT)
13.787 @ 100.49 - (1.985/60') scrming - A6 - (DR's, Injen, JBA Shorty Headers, MRT 2.0, Trifecta Tune) (LLT)
Power Adders (Forced Induction):
1. 11.268 @ 120.11 - MagnumForceGB - A6 - (305/55/18 Nitto NT05R, Vortech SCi w/2.91" pulley, 81mm Throttle body, Ported LFX manifold, ARH LT Headers, ARK DT-S, Water Methanol Injection, 3.91 1LE Gears, JRE Posi Mod, 1LE Axles/Hubs, BMR Trailing Arms, Toe Rods, Subframe Bushings, UCA Bushings, Circle D 5C Torque Converter, Custom HP Tuner tune) (LLT) Post # 2565
2. 11.756 @ 122.75- 2012SIMRS- A6- (Goodyear F1 tires, IPF Supercharger Kit, Overkill Tune, 80mm TB, 3.91 1le Diff, FTI Converter, ALKY meth injection) (LFX) Post #2659
3. 12.123 @ 119.88- JantzenOKC- A6- (Fabberge twin turbo, resonated xpipe & muffler delete, 93 octane tune) (LFX) Post #2430
4. 12.559 @ 110.75- Bigalan7- A6-(Overkill superecharger, ALKY injection, 3600 custom stall converter, Asanti 22” 3 piece wheels, 295/30/22 Nittos) (LFX)
5. 12.809 @ 110.90 - Det_Duke - A6 - (LLT IPF supercharger BBK's, HF cats, ice-o-later) (LLT)
6. 12.92 @ 107.32 - V6owner - A6 - (M/T Drag Radial's, BBK LT headers, ported TB, 3/8" icolater, BMR trailing arms/bushings, pfadt drop springs, standard super charger pulley) (LLT)
7. 13.06 @ 103.19 - BaylorCamaro - A6 - (Nitto 555r street DR's, ARH LT headers, ported TB, PFADT drop springs, RX Supercharger, Ported & Polished IM, IM Spacer) (LLT)
8. 13.09 @ 107.27 - efpardo - A6 - (DR's, RX Supercharger, ported TB, Solo HF Cats, Livernois Tune) (LLT)
9. 13.408 @ 105.51 - sycraft - M6 - (IPF Supercharger, Solo Cats and exhaust. Ram twin disc clutch, LSR Suspension (Road Course setup) Nitto NT05) (LFX)
10. 13.69@ 102.45- derek1387- AY6 Manual- (KPE Supercharger, 3.48" Pulley, Treadstone Intercooler, MKC 3" piping, VMAX PTB, Jacfab Spacer and ported manifold, Overkill tune, 3.91 gears, BFGoodwrich Sport Comp) (LFX)
Honorary Mention
14.12 @ 104 - iceman5730 - A6 - (IPF Supercharger, Vmax TBody,Eibach Pro Kit Sway Bars/Springs, Poly sub frame Bushings,GMPP Exhaust)(LLT)
Power Adders (Nitrous):
1. 11.841 @ 113.98 - HDRS - A6 - (125hp shot Nitrous, Injen CAI, MRT V2 exhaust ) (LLT)
2. 12.015 @ 113.03 - ROD1 - A6 - (Zex Nitrous 125 shot, DRs/Skinnies, Injen CAI, ARH Longtubes/High Flow Cats, MRT v2.0 Axle Back, Trifecta Tune) (LLT)
3. 12.039 @ 109.22 - etmx183 - A6 - (Drag radials, Solo HFCs, GMPP mufflers, 3400 FTI convertor,RX ported throttle body, CAI Intake W/air scoop, 3.91 gears W/complete SS posi diff swap, BMR Diff and cradle bushings, toe arms, trailing arms, tunnel stiffener and drivesahft loop, NYTREX nitrous 140hp level, HP Tuners software, Tuning by Matt@FSP) (LFX)
4. 12.109 @ 109.45 - RetroRallySport - A6 - (v max, t/b jacfab intake and spacer, underdrive pulley, solo cats, magnaflow exh, zl1 pump, fti 3200 convertor, 3.91 gear, weld rts wheels, m&h racemaster tires, nitrous outlet 100 shot) (LFX)
5. 12.145 @ 113.86- Twin Town Terror--A6- (Elite catch can & clean side oil separator, Apex Scoop, CAI cold air intake, Vmax ported throttle body, TTT ported intake manifold, JacFab intake manifold spacer, Magnaflow cat back exhaust, Circle D converter, Jegs Spike wheels, MT 28/6/17 f and 295/60/15 r tires, Carlyle 15” wheel conversion kit, 3.45 SS rear end, Nitrous Outlet plate kit, 125hp jets) (LFX) Post #2672
6. 12.349 @ 112.81 - IneedAZ -A6 - (MT 18" DR, CAI w/scoop, jacfab intake, VmaxTB, HFC, Dynomax mufflers, 100shot, 3.91 gears, 3200 FTI convertor, HPTuners) (LFX)
7. 12.587 @ 111.25 - (1.889/60') racergirl - A6 - (Stock BFG's, CAI, MRT 2.0, SLP under drive pulley, 75 shot) (LFX) post # 2447
8. 12.808 @ 109.04 - TexasCamaro5 - A6 - (Mickey Thompson ET Street Radials mounted to 18" Z06 replica wheels and stock 20's on the front, Cold Air Inductions cold air intake w/ ADM air scoop, VMax TB,- Stainless Works LT Headers, Solo Performance Mach X-LLT cat-back exhaust w/ j-pipes, Circle D 3200 stall torque converter, SS drive-shaft, Limited-Slip Differential w/ 3.42 gear ratio, SS rear axles and rear hubs, Transmission cooler, Cold Fusion Nitrous injection system (100-hp wet shot this time around), Pfadt suspension) (LLT)
9. 12.832 @ 109.59 - X-Factor - A6 - (100 shot Ny-Trex, Vararam CAI, MRT V2 Axel-back with a MagnaFlow Resonated X-Pipe, Resonators deleted, Iceolater, Brembo Brakes, 1LE Track Pack, H&R Lowering Springs, Mickey Thompsons) (LLT) #2582
10. 13.004 @ 102.52 - FrankieBee -A6 - (ARH, Injen CAI, Trifecta NOS Tune, Nytrex 100 shot, SS Posi rear with 3:45, V Max Black Ice-Olator, ported TB, 3400 TCI converter, SJM line-lock) (LLT)
Honorary Mention
13.26 @ 105.88 - Superfly1 -A6 - (CAI intake, OBX LT, Trifecta tune, 100 shot)
Bolt-Ons
1. 13.656 @ 100.54- MagnumForceGB- A6- 305/55/R18 Nitto NT05R, 81mm Throttle Body, Ported LFX manifold, ARH LT Headers, ARK DT-S, 3.91 Gears, Circle D 5C Torque Converter, Custom HP Tuner tune, MACE 210/210 Cams, 85# Valve Springs, Ported Cylinder Exhaust Ports
Power adders (Forced induction)
1. 10.692 @ 126.42- bowtieracer- A6- (M&H Race Master DRs, Twin Turbo, forged internals, meth injection, circle D triple disk converter, 3.27 gear, RTS wheels, GPI fuel enrichment and tune) Post #2601
2. 10.752 @ 131.13- JantzenOKC- A6- (305/45r18 NT05r, Twin Turbo, forged internals, methanol injection, triple disc stall converter, BMR suspension, drag radials, M&H Racemasters, ARK exhaust, 3.27 SS diff, 25 shot nitrous) Post #2625
3. 11.140 @ 120.90- djcolopi- A6- (Twin Turbos-GTX2863R; JacFab Forged Rods; Diamond Forged Pistons; Mace 100lb Valve Springs; Exhaust Cam; JacFab IM; 80mm TB; RX 4000 Single Disc; ZL1 Fuel Pump; Exhaust Cam, 3.27 LSD; SS Brakes; BMR Drag Suspension; DSS 3.5" Aluminum Driveshaft; Dark Star 17x4.5 & 17x10.5; Drag Wing; Corbeau FX1 Pro Seats; Rear Seat Delete; Radio Delete; AC Delete; 5pt Harness; MT ET Street R’s) Post #2631
4. 11.498 @ 95.91 (low trap speed due to blown engine) -GretchenGotGrowl - A6 - (Twin Turbo, GPI Fuel Enrichment, 4000 CircleD Single Disk Stall, ZL1 fuel pump, Meth Injections, 3.45 gears, 10:1 forged pistons, Nitto 555 Extreme II (Front)/Slicks (Rear)) (LFX)
TOP 10 FASTEST V6 CAMAROS
4. 11.268 @ 120.11 - MagnumForceGB - A6 - (305/55/18 Nitto NT05R, Vortech SCi w/2.91" pulley, 81mm Throttle body, Ported LFX manifold, ARH LT Headers, ARK DT-S, Water Methanol Injection, 3.91 1LE Gears, JRE Posi Mod, 1LE Axles/Hubs, BMR Trailing Arms, Toe Rods, Subframe Bushings, UCA Bushings, Circle D 5C Torque Converter, Custom HP Tuner tune) (LLT) Post # 2565
5. 11.498 @ 95.91 -GretchenGotGrowl - A6 - (Twin Turbo, GPI Fuel Enrichment, 4000 CircleD Single Disk Stall, ZL1 fuel pump, Meth Injections, 3.45 gears, 10:1 forged pistons, Nitto 555 Extreme II (Front)/Slicks (Rear)) (LFX)
6. 11.756 @ 122.75- 2012SIMRS- A6- (Goodyear F1 tires, IPF Supercharger Kit, Overkill Tune, 80mm TB, 3.91 1le Diff, FTI Converter, ALKY meth injection) (LFX) Post #2659
7. 11.841 @ 113.98 - HDRS - A6 - (125hp shot Nitrous, Injen CAI, MRT V2 exhaust ) (LLT) Post # 1237
8. 12.015 @ 113.03 - ROD1 - A6 - (Zex Nitrous 125 shot, DRs/Skinnies, Injen CAI, ARH Longtubes/High Flow Cats, MRT v2.0 Axle Back, Trifecta Tune) (LLT) Post # 449
9. 12.039 @ 109.22 - etmx183 - A6 - (Drag radials, Solo HFCs, GMPP mufflers, 3400 FTI convertor,RX ported throttle body, CAI Intake W/air scoop, 3.91 gears W/complete SS posi diff swap, BMR Diff and cradle bushings, toe arms, trailing arms, tunnel stiffener and drivesahft loop, NYTREX nitrous 100hp level, HP Tuners software, Tuning by Matt@FSP) (LFX) Post # 2232
10. 12.109 @ 109.45 - RetroRallySport - A6 - (v max, t/b jacfab intake and spacer, underdrive pulley, solo cats, magnaflow exh, zl1 pump, fti 3200 convertor, 3.91 gear, weld rts wheels, m&h racemaster tires, nitrous outlet 100 shot) (LFX) Post # 2427
Honorary Mention
12.349 @ 112.81 - IneedAZ -A6 - (MT 18" DR, CAI w/scoop, jacfab intake, VmaxTB, HFC, Dynomax mufflers, 100shot, 3.91 gears, 3200 FTI convertor, HPTuners) (LFX) Post # 2328
12.559 @ 110.75- Bigalan7- A6- (Overkill supercharger, Alky Injection, 3600 custom stall converter, Asanti 22 in 3 piece wheels, 295/30/22 Nittos)
12.587 @ 111.25 - racergirl - A6 - (Stock BFG's, CAI, MRT 2.0, SLP under drive pulley, 75 shot) (LFX) post # 2447
12.808 @ 109.04 - TexasCamaro5 - A6 - (Mickey Thompson ET Street Radials mounted to 18" Z06 replica wheels and stock 20's on the front, Cold Air Inductions cold air intake w/ ADM air scoop, VMax TB,- Stainless Works LT Headers, Solo Performance Mach X-LLT cat-back exhaust w/ j-pipes, Circle D 3200 stall torque converter, SS drive-shaft, Limited-Slip Differential w/ 3.42 gear ratio, SS rear axles and rear hubs, Transmission cooler, Cold Fusion Nitrous injection system (100-hp wet shot this time around), Pfadt suspension) (LLT) Post # 1605
60' TIMES, from Top 10 Fastest V6 Camaros
1. bowtieracer- 60’: 1.656- DA: 1155 ft
2. JantzenOKC - 60': 1.804 - DA: 3000+ ft
3. Djcolopi- 60’: 1.657- DA: -312 ft
4. MagnumForceGB - 60': 1.644 - DA: 2278 ft
5. GretchenGotGrowl - 60': 1.818 - DA: 32 ft
6. 2012SIMRS- 60': 1.857
7. HDRS - 60': 1.616 - DA: -354 ft
8. ROD1 - 60': 1.716 - DA: -935 ft
9. emtx183 - 60': 1.637 - DA: -1256 ft
10. RetroRallySport - 60': 1.609 - DA: -500 ft
11.77 @ 119.21
Old 01-18-2010, 03:47 PM   #4
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
I'll play.
Tires used on the pass: Stock (19")
Performance Mods (if any): Airaid intake, GMPP axle back
Category submitted for: couple bolt on's
R/T.......... 1.964
60'........... 2.244
330'...........6.151
660'...........9.335
660’ mph... 75.41
1000'..........12.105
1320'..........14.447
1320’ mph… 97.03
Name of the track: Atco Raceway
Date of pass: 12/4/09
Weather conditions: (include Density Altitude, if known): 54* DA -651
67 GTO is offline   Reply With Quote
Old 01-18-2010, 03:50 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
BackinBlackSS/RS is offline   Reply With Quote
Old 01-18-2010, 04:40 PM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Tires used on the pass: Stock 20" RS wheels/tires
Performance Mods (if any): MRT Axle back, IAT relocation
Category submitted for: Bolt-ons
R/T.......... .606 (.500 tree, with .500 being perfect)
60'............. 2.086
330'...........
660'........... 9.331
660’ mph... 80.60
1000'..........
1320'.......... 14.323
1320’ mph… 97.75
Name of the track: Lapeer Dragway - Elevation 826 feet
Date of pass: 9/19/2009
Weather conditions: believe it was 70ish, clear... I think the DA was about 1600..
scrming is offline   Reply With Quote
Old 01-18-2010, 05:04 PM   #7
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
I'm in...
Tires used on the pass: 20" P Zeros
Performance Mods (if any): Airaid CAI and MRT V1 exhaust
Category submitted for: bolt ons
R/T.......... .660
60'............. 2.049
330'........... 5.924
660'........... 9.110
660’ mph... 75.95
1000'.......... 11.868
1320'.......... 14.184
1320’ mph… 96.43
Name of the track: PBIR
Date of pass: nov 28 '09
Weather conditions: (include Density Altitude, if known): 276
Beauwulf is offline   Reply With Quote
Old 01-18-2010, 05:19 PM   #8
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Keep 'em coming.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 01-18-2010, 05:21 PM   #9
BackinBlackSS/RS
Go Blue!!!!!
Seeing those MPH's, your et's have room for improvement.
Old 01-18-2010, 05:24 PM   #10
Beauwulf
Beauwulf's Avatar
Yea... soon as we get past this torque management deal! I fugure we're losing 20-30 HP in 1st and 2nd gear!
Old 01-18-2010, 05:38 PM   #11
67 GTO
13.453 @ 101.90
67 GTO's Avatar
WTF, I was in first place all of an hour or so This coming spring should be fun.
Old 01-18-2010, 05:41 PM   #12
Xanthos
PWA Relapse
Xanthos's Avatar
Should have taken a screenshot.
- X
Old 01-18-2010, 05:52 PM   #13
67 GTO
13.453 @ 101.90
67 GTO's Avatar
- X
Nah, I'm glad we have many great V-6 enthusiast's here, makes owning my car that much more enjoyable.
Old 01-18-2010, 07:21 PM   #14
scrming
scrming's Avatar
Agreed... a little competition to keep us going is great! And yes, spring time is going to be very interesting! Especially the FEST!
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 10:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 04:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 12:31 PM
