04-23-2016, 09:24 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Hammerhead rear reviews
Any long term updates from those of you who are running the Hammerhead differential? Wondering how it's holding up...
Few more q's... What is the weight of the Hammerhead compared to SS and Zl1 diff? How's the emitted noise? What's the price of the Hammerhead? |
04-23-2016, 10:42 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
He's working on a new, stronger aluminum housing. Not sure of the ETA. The older one was 30lbs lighter than the ZL1. Had a noise channel between diff housing and subframe, could be ground down. Current RDM price http://etenterprises.com/camaro-complete-the-kit-form/.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-23-2016, 11:13 PM | #3 |
What about the Lingenfelter diff? Is that lighter than the HH?
04-23-2016, 11:30 PM | #4 |
No. It's about 10-15lbs heavier.
If my memory serves, it goes: HH < Lingenfelter < 9" < ZL1 Pricing: ZL1 < HH < 9" < Lingenfelter
04-24-2016, 12:47 PM | #5 |
Do you have the actual weight of the stock SS diff and all these we've been mentioning?
04-24-2016, 01:22 PM | #6 |
I'll slap one on the scale tomorrow and post.
04-24-2016, 02:46 PM | #7 |
Awesome. Thank you brother!
04-25-2016, 05:12 PM | #8 |
76-1/2 little pounds.
04-25-2016, 09:48 PM | #9 |
04-25-2016, 10:17 PM | #10 |
Gosh, make me work at it! I was wrong (earlier) on the difference between HHD and LPE.
Stock SS ..... 76 lbs HHD ......... 112 lbs LPE ......... 115 lbs Ford 9" ..... 124 lbs ZL1 ......... 135 lbs
04-25-2016, 10:35 PM | #11 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Thank you!!
04-26-2016, 09:28 AM | #12 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I don't suppose you could elaborate on this. I have one I bought used that was supposed to have been just rebuilt, but it has a mean deceleration noise. No shavings in the fluid, but man is it annoying. I've read this should be a pinion pre-load problem, but I'd be interested to know what you mean by noise channel and what could be ground down to help.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-26-2016, 11:27 AM | #13 | |
Man...that ZL1 diff is a pig. 75 more pounds than the stock diff... |
04-26-2016, 12:00 PM | #14 |
Actually 59lbs lol but yeah its a big girl
