04-17-2021, 03:32 PM | #29 |
Drives: 2018 Camaro 2SS Join Date: Jan 2021
Just did this to my '18 2SS & got an "On-Star: An issue with the airbag system has been detected" email.
Does this mean I did it right? lol No CEL, just that notice Last edited by KindaOrange; 04-17-2021 at 04:23 PM. |
04-22-2021, 03:19 PM | #30 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
But doubtful this will cause any problem. And if your seats go back further, you did it right. |
04-24-2021, 11:38 PM | #31 |
Drives: 2021 Chevy Camaro ZL1 Coupe M6 Join Date: Apr 2021
Awesome, thank you!
04-26-2021, 02:28 PM | #32 | |
No issues ever since. Also, for those with the A8, get the Range AFM Disabler. It is FANTASTIC! Car rides 100x smoother than before. No more disgusting sounding, clunky v4 mode punch in & out. 10/10 highly recommend |
04-29-2021, 09:15 PM | #33 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Hello , safe to assume this can be done for Racaro seats? Also what seat position is best to disconnect the wires and perform the procedure in general? Thank you
05-02-2021, 11:04 PM | #34 |
GM what were you thinking? Even with a grinder I spent most of the weekend working on this mod. If you use a grinder make sure you move everything out of the way especially that cable with the black housing. As the OP stated, a magnet helps to get the pin out. Thank you for turning us onto this mod. I found the below video to assist on seat removal.
https://m.youtube.com/watch?v=7kEPtLMQLPI&t=197s |
09-27-2022, 05:11 AM | #35 |
Drives: 2017 2SS Convertible Join Date: Mar 2021
Question - I am looking at the photos and position of the pin to drill and can't stop wondering - can all this be done without having to remove the seat? (removing the seat is the most difficult part - it is heavy, you can hurt yourself and of course you can damage the car)
What if you put it max to front and max up - you should have access from the side, right? If I am not wrong for the passenger seat you are drilling from the outside side. Just disconnect the battery, then seat connector, remove the plastic covers, unzip the zipper and you should be ready to drill, correct? Or am I missing something? BR, Jarek
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) Last edited by Jarek; 09-27-2022 at 07:43 AM. |
10-24-2022, 06:30 AM | #36 |
Any thoughts on the above suggestion for those who applied or thinking about applying this mod?
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) |
10-24-2022, 04:17 PM | #37 |
Drives: Blown C7 and 6th gen Join Date: Aug 2012
No you can't. Here is another issue. You are drilling a metal pin out which results in flaming hot shavings. You would trash your interior. I took the seat out, but left the seatbelt attached. No problem. It is awkward and heavy. Have a big breakfast. To date the best mod I have did to my C4/5/6/7/8 and Camaro. LOL
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL 17 Camaro 2SS 50th edition. TOTALED 6/2019 K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system 17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system. |
01-29-2024, 11:11 AM | #38 | |
However if you put proper covers on the floor, seats, door sill (I don't expect hot shavings to reach the roof or open door - not enough kinetic energy) or even better to add to that (as someone suggested before) a strong magnet to fetch the shavings before they go flying, this should be doable, right? I was wondering if you have a proper access to start drilling when the seat is still in the car but nobody is raising concerns.
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) Last edited by Jarek; 01-30-2024 at 05:00 AM. |
04-12-2024, 04:13 PM | #39 | |
Drives: 2023/2SS/1LE/RadiantRed/A10 Join Date: Jul 2022
There are pins on both sides of the seat. You have to drill 4 holes. So you have to remove the seats to reach the two inner drilling points. Sent from my iPhone using Tapatalk
2023/2SS/1LE/Radiant-Red/A10/Sunroof/Copper-Free-Breaks/Navigation —— Order History: 6/17/22-1100, 3/7/23-3000, TPW-4/3/23, 4/4/23-3800, 4/8/23-Delivered
05-01-2024, 12:35 PM | #40 |
Drives: triple black 98Z Join Date: Mar 2012
I used this videos method for the first one... for the second I tried what he suggested and used a long file, hammer and left the seat in the car. Hit the stoppers and they broke off. Its even easier but an admitted hack compared to the way he did it in the video.
https://youtu.be/dIB7fq8EjwI?si=kawhmnqwUo2eJSpe |
