dave@hennessey
Old 02-02-2012, 10:07 PM   #29
Kyle.Gilmour
Charter Circle Member
Kyle.Gilmour's Avatar
Drives: 427 LSX- with TWINS
Location: Back in Michigan!! Do miss ATX and my Tejas friends
Send a message via AIM to Kyle.Gilmour
Originally Posted by JUISSD View Post
So they recommend getting the controller but you can't even use it?
yea... can you elaborate on that pyr0b0y
are you not using the controller?
Kyle.Gilmour is offline   Reply With Quote
Old 06-06-2012, 03:43 PM   #30
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I have talked with them alot over the last few weeks about the eliminator fuel pump I plan on only making 750 to 780 whp however I'm going to take advantage of e85 they told me you need a tach adapter which I went with the autometer I picked it up for like 60 bucks I've never herd what the sound like in the car if someone has one of the camaro intank they should post it but you do have to route a new line and return system as far as tuning you just need to go in and turn off the parameters to the fuel pump because the speed controller will act as a stand alone the just adjust your fuel pressure to what you need as you tune. That tach adapter is autometer 9117 and they have a great write up where they actually put it on the gen 5 camaro they hooked it up to a shift light but same concept the speed controller
Trob85 is offline   Reply With Quote
Old 06-23-2012, 04:36 AM   #31
incon3037r
GMHIC
incon3037r's Avatar
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT
I ordered one of these pumps for my G8 for $631. If you do some searching there are some pretty good deals.
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 11psi on E85 using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners
incon3037r is offline   Reply With Quote
Old 06-23-2012, 09:28 AM   #32
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
One thing to remember is that the Eliminator is loud pump. It just is. The A1000, even thought the same dimensions is considerably quieter especially with the controller.
If you listen to this video closely you can hear the Eliminator (in-tank) pump kick on at 21-22 seconds into the video. That almost 'hissing' or 'rush of air' noise is the pump. We have it set to preload the C-16 fuel pressure based on TPS and kPa.
http://www.camaro5.com/forums/showpo...postcount=4780
speedster is offline   Reply With Quote
Old 06-23-2012, 10:20 PM   #33
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
a friend,s first mention was " wow is that fuel pump loud"...just what he happen to mention, so don,t expect a hmmm...if noise is not a issue, then go for it..but i would try to hear 1 first hand, if this is gonna be a driver more then a track car..imo
mikepage0007 is offline   Reply With Quote
Old 06-25-2012, 09:21 AM   #34
Kyle.Gilmour
we fired my car up this weekend with the new twins and eliminator pump. The speed controller was faulty and had to be sent back. We have the new one, it is just not installed yet.
When you turn the key, yes, you can hear it... loud... maybe, but that is up the person I guess. I never noticed it driving down the road.
Old 06-25-2012, 10:47 AM   #35
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
This is good to hear. You would think the way many describe the pump that the only thing you can hear is the loud whine of the pump over everything else.
I have my whole box of Aeromotive goodies ready to be installed, just waiting for the motor to be assembled by HKE. Finally got in the Dragon Slayer which was the only remaining piece of the puzzle. I imagine with the speed controller the pump will be a little quieter.
I was losing sleep over which fuel lines and fittings to use but my builder uses the Goodridge lines and fittings and has good luck with them. I was leaning toward the Earls Ultra Flex 650 teflon lines but i was assured they were not necessary. Damn expensive too!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-25-2012, 12:38 PM   #36
DW Machine
In Process
Drives: 2010 Camaro SS
What other components did you guys choose to go with for +1000hp in terms of Fuel Rail upgrade, Regulator and line for the return?
DW Machine is offline   Reply With Quote
Old 06-25-2012, 12:51 PM   #37
Kyle.Gilmour
i bought everything that Aeromotive had to offer to go with the Eliminator... I believe the lines came from them as well.
Old 06-25-2012, 01:15 PM   #38
BullF-16
BullF-16's Avatar
Eliminator stealt intank pump,Aeromotive pro series return regulator, Aeromotive billet fuel speeed controller, Aeromotive 40 micron filter, aeromotive LS7 fuel rails, aeromotive Y block, -10 and -8 Goodridge braided fuel line and connectors and numerous ORB to AN fittings from Aeromotive. Also an Autometer RPM adapter so the speed controller can read the RPM signal
Old 06-25-2012, 02:08 PM   #39
BullF-16
BullF-16's Avatar
I did a whole bunch of research on fuel systems and came up with the big Aeromotive pump as my plan. Liked it over dual and triple pump setups for the safety factor. If the pump quits your motor shuts down vs if one of the triple pumps fails you run the risk of leaning out your motor. It took a number of hours to track all the info down but here is a thread with all the part numbers minus the fuel line connectors and the fuel lines.
http://www.camaro5.com/forums/showthread.php?t=226958
Old 06-25-2012, 03:34 PM   #40
DW Machine
In Process
Bull - This is a HUGE help - Thanks for all the info!
Kyle - Great pictures - Thanks for the help.
Old 06-25-2012, 03:42 PM   #41
BullF-16
BullF-16's Avatar
Im glad, i did a whole bunch of research and talking to different companies to include house of boost, aeromotive, lonnies, Dallas Performance etc and my shop SNLPerformance. There are a bunch of options out there. When i finally get this setup going i will definitely post my results here.
When it came time to order everything, I couldnt believe how hard it was to spent the money on it....no one seemed interested in my money it seems. Finally Livernois came thru thanks to a recommendation from SSE 4 2SS. Made one call and it was ordered. Got the box of goodies a week ago.
Good luck!
Old 07-26-2018, 02:35 PM   #42
Loonbry
Drives: 2015 Camaro SS
Anyone know the e85 capability ?
Loonbry is offline   Reply With Quote
aeromotive, fuel, fuel delivery, gasoline, pumps
*/* Aeromotive Billet Fuel Rails/ Russell fuel System upgrade kit */* ImportImage Engine Internals 60 10-11-2011 12:56 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
