05-08-2024, 08:22 PM | #15 | |
Why would it affect durability…? It’s literally the same bypass…just opened electronically, not by vacuum.
05-11-2024, 09:20 PM | #16 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Ordered the 555R2 hopefully itll make the car atleast usable. Should get here next week
Florida High Performance: H/C Whipple LME 377 900WHP
05-15-2024, 02:34 PM | #17 |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
Toyo RR and the latest/greatest Toyo R will be about the best you can do on the street but you will sacrifice tread pattern to do it. I'm going to try the Toyo RR out in a 315/30/20 when they arrive at the end of this week. I run a 345/35/18 Toyo RR on my C7Z and it does really well IMO.
05-16-2024, 12:13 PM | #18 | |
@Blackmamba_1LE
It seems the 555R2 will tick most of the boxes. Tire shop informed me that tires arrived early but too busy at work. May install Friday or Saturday by latest.
05-16-2024, 03:25 PM | #19 |
Looking forward to seeing your results with the 555R2. If they really do hook well then I’d go that route next time instead of the R888R.
05-16-2024, 06:54 PM | #20 |
The Toyo RR is very quiet. The R888R is the one that roars.
05-17-2024, 02:16 PM | #21 | |
@Blackmamba_1LE
INSTALLED! Nitto 555R2 305/30/20
Anywho, was able to get to the tire shop early before work and get them installed. Traffic is just too stupid in Miami to so some pulls, i'll see if I can take her out for a spin tonight and see what's up with the tire. Initial impressions... in 95* tires are super quiet, was only able to drive up to 50mph due to morning rush hour. Currently at 35PSI and i dont feel like its picking up every rock... for better or worse... compound does feel stickey... almost like my MT R's but it should as its supposedly the dame "R2 compound" Love the fact that they come in 305/30/20... so you need to look twice to really notice its "on a tire". Some pics:
05-17-2024, 04:09 PM | #22 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
you might lower the pressure to 25-26 for driving on the street, the centers wear out quickly if pressures are high.
05-17-2024, 05:32 PM | #23 |
@Blackmamba_1LE
Will definitely lower it a bit. Thats just how the shop gave them to me. I was under the impression that over inflated makes tires last longer. Or maybe thats for fuel savings.
05-17-2024, 10:34 PM | #24 |
Over inflating will wear the middle of the tire out like already mentioned, ride worse and hook worse but it may increase fuel mileage.
05-21-2024, 09:33 AM | #25 |
@Blackmamba_1LE
Alright so did a few testings at 35PSI... 3rd gear 60MPH hit the car hooked like a dream
Tried to do a 40MPH hit in 2nd gear and the car definitely didn't like that, nannies were flashing like crazy. Next, will air down to 23psi and Re-test based on how aggressive the 40 was, I don't expect much difference even at 23psi but we will see. Definitely an improvement over the Michelin 4S's before at 80 I wasn't able to hit it. Glad to have more confidence driving now. Ohhhh and turning, as expected NOT as good but useful, just can't go crazy as you could on a R888 or the Michelins but understandable as this is considered a drag tire.
05-21-2024, 10:07 AM | #26 | |
05-21-2024, 10:10 AM | #27 |
23 makes a difference in traction with the 555r2. My best no prep 0-60 is 3.0 (no roll out) at 23psi. Up at 28psi, 3.3 is the best I can get. And they hook better from a second gear roll too. I do usually drive with them at 28psi.
2016 NFG 1SS A8
05-21-2024, 11:17 AM | #28 | ||
@Blackmamba_1LE
Ohhh and by the way... the results posted before are NO burnouts or anything extra to get heat in them... just a hot day in Florida and a 6-8min drive on to the highway before ripping it. They have about 100 miles in now (getting the new tire grease out) so they should perform a bit better. Overall, happy with them.
