09-11-2023, 12:14 AM | #15 |
Electrical Engineer
The factory radio is comprised of two pieces – the screen that you see and the brains that you don’t see.
There is one harness to intercept these signals and it’s the PAC LPHGM72. The factory amp here is buried in the dash. We want connectors X1 and X2 The adapter goes in-line and has removable bypass clips. Of course, we want to wrap the connectors and cabling with fabric coating, like OEM. The floorboard will need some treatment as well.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
09-14-2023, 11:50 PM | #16 |
Electrical Engineer
Finshed a layer of Resonix CLD on the inner door skin, and then used Resonix Moldable Barrier to close up the openings. Using the barrier was a joy compared to my traditional methods of aluminum sheets with CLD and CCF.
09-15-2023, 07:50 AM | #17 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
wow, and wow. It will be the most quiet car to make a phone call in that I have ever seen. Did you replace the stock amp?
09-15-2023, 11:08 AM | #18 | |
Electrical Engineer
I am adding a sound system, yes, and it will be designed to be competitive in IASCA and MECA for sound quality competition - meaning it will be pretty darn nice and will sound amazing. Most of this effort is to make the sound system shine. Low road noise means you get to hear musical dynamics.
09-19-2023, 04:47 AM | #19 |
Looking forward to seeing more of this amazing work.
If you are inclined, maybe you can post the raw RTA for each of the drivers once the system is up? I'd love to compare and see if you see the same cancellations in the same spots.
2021 2SS A10 - Summit White - NPP - MRC - Adrenaline Red Interior Pkg - Black Appearance Pkg - Ground Effect Pkg - Suede Steering Wheel and shifter - Red Calipers - Carbon Flash Wheels w black lug nuts - DD Tinted Side Markers - Hero Tinted Rear Reflectors - Redline Fender Badges - 20% Tint
Audio System Build Log ----------------------------------------------------------- 2014 Z/28 Summit White - sold 2020 2010 2SS/RS Summit White - sold 2014 |
09-19-2023, 09:39 AM | #20 | |
Electrical Engineer
I will be taking RTA measurements of the factory amplifier output (I use a LOC to convert the output to low level then run into a soundcard to see what the stock EQ curve looks like). Then I use the DSP to flatten that prior to doing any acoustical tuning. This is done by bringing the signal into the DSP and using that input channel for factory EQ shaping, then I run the signal out then back into another input so I have separate EQ for acoustic tuning. Note that when taking measurements, I will likely use a microphone array to alleviate the nulls and peaks that occur with a stationary mic.
09-19-2023, 09:51 AM | #21 |
Electrical Engineer
Almost done with the door speaker brackets, they weigh about 10x as much now and are acoustically dead. Just need fasteners, will be using 6-32 bolts. This is also a view of the drivers being used. Hertz is my go-to speaker manufacturer and what we have here is a ML28 tweeter, HL70 midrange, and ML165 woofer for a front 3-way. The HCX-690 will go in the rear deck but will be turned off for windows-up SQ listening with an excellent sound stage, and the rear 6x9 will be engaged for windows-down louder listening without a focus on a sound stage. I'm excited to hear what the rears can do when they are that close to the rear glass. The challenge is that I'll need to build enclosures for the rear deck speakers so the subwoofer doesn't manipulate them. It's a lot of work for something that will usually just be off.
Ready to start treating the floor:
09-20-2023, 01:06 AM | #22 |
Drives: '24 ZL1 A10, '70 Olds 442 W-30 Join Date: Sep 2023
Very nice build log Keep, excellent photos and information. It's going to be an amazing sound system
09-20-2023, 05:33 AM | #23 | |
I find that the passenger side MB (GB60 for me) has a huge cancellation at around 520Hz and both MB have a cancellation at 110Hz and 400Hz Following you on DIYMA as well
09-20-2023, 09:31 AM | #24 | |
Drives: 6th Gen LT1 Join Date: Jun 2023
09-20-2023, 11:09 AM | #25 | |
Electrical Engineer
We saw the attempt at "deadener" in the doors along the outer skin (the stuff that I just peeled off).
09-21-2023, 07:12 PM | #26 | |
Isn't the dynomat effect also the weight that adds to the panel? the thicker and heavier the better? I can imagine they might have equipment to measure a "sound heatmap" to be able to determine in which places apply the sealant. |
09-25-2023, 01:12 PM | #27 | |
Electrical Engineer
I have used acoustical cameras before, and am trying to build a 360 acoustical camera with low frequency resolution. I agree that they likely determined what and where, using as little product as possible.
09-28-2023, 07:23 PM | #28 |
Electrical Engineer
Been busy, but made a bit more progress getting the front door midbass speakers installed. Used 6-32 bolts and nylon locking nuts and washers, all stainless steel.
Gasketing options, I choose what makes the most sense for the application. Ready for mounting to the door:
Tags |
acoustic, audio, speakers, stereo, subwoofer |
