Old 10-24-2022, 07:44 PM   #15
L78toLT1
L78toLT1's Avatar
Originally Posted by Trochoidal View Post
I see pin 71 & 72 on X2 as unoccupied and pin 73 as ground for LT1 (2017 manual) page 11-668.
I see pin 72 on X3 as DFI High supply and pin 73 as ground for LT1 (same manual) page 11-680.
This may not be relevant to your setup, but I wanted to take a look to be a 2nd/3rd set of eyes.
Although the noid test did show no signal for pins 45-52.
You're correct on all counts, Trochoidal. I drafted the previous message, from the comfort of my couch, from memory. At my age, I should know better. Nevertheless, aside from referencing the wrong plugs/pins, the info in the preceding message is correct with regards to the harness and ground integrity. I was mistaken in an earlier message, however, when I stated that I had 4.5V on the power wires. I thought I read 4.5ish volts on my VOM, but after finally locating, and reading the diagnostic procedure in the manual, I saw where these wires should check less than 1v. I rechecked mine and they all read .45ish volts (still don't like these newfangled digital meters. I never would have made that mistake with my old analog VOM).
Noid test showed a signal on left bank pins 49 thru 52 as expected, the damn thing will run on four cylinders after all. Pins 45 - 48 have continuity, but no signal.
Baby Blue
Old 10-25-2022, 09:27 AM   #16
JANNETTYRACING
JANNETTYRACING's Avatar
I will caution you to not flash the Modified tune file in to the New ECM it may Brick it.
Take a read on the new ECM and send it to me, I will make you another tune file to use.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-25-2022, 12:35 PM   #17
L78toLT1
L78toLT1's Avatar
Thanks Ted. I believe that I understand the process, but will call and run through it with you when I get the new ECM installed, just to be sure.
Baby Blue
Old 10-25-2022, 10:04 PM   #18
Trochoidal
Drives: 2017 Camaro 2SS A8
Damn, I was hoping something would work in your favor and maybe it was a ground issue. New ECM inbound.
Old 03-18-2024, 12:45 AM   #19
Keithj3
Drives: 2016 camaro
Did you ever get this straightened out seem to be having a similar issue.
Keithj3 is offline   Reply With Quote
Old 04-13-2024, 10:10 AM   #20
JANNETTYRACING
It was a failed ECM.
