11-16-2018, 11:38 AM | #15 | |
2016 NFG 1SS A8
11-16-2018, 02:09 PM | #16 |
SABIO
BTR stage 1 here. Nice sound and lope but not crazy
Decent power.
11-17-2018, 07:33 PM | #17 | |
Drives: C5 Z06 LS7 Join Date: Jun 2014
11-19-2018, 09:50 PM | #18 |
Drives: 2017 Camaro SS 2ss Nightfall Gray Join Date: Aug 2018
EDFHOBBIES I couldn't agree more. Highlander is that what you run?
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels Roto fab Biggulp CAI Full paint correction with cquartz finest ceramic coating Whipple 2.9 ARH Long tube headers with High flow cats 1le sway bars F&R BMR Upper and lower trailing arms Hurst short throw shifter |
11-20-2018, 07:35 AM | #19 |
Drives: Camaro Join Date: Sep 2018
This is the only one I would ever use, Lingenfelter has been doing this for 45+ years.
https://www.lingenfelter.com/product/L210306914.html |
11-20-2018, 08:23 AM | #20 |
Drives: 2018 2ss 1le Join Date: Jan 2018
I'm sure this has been covered but what is stock cam specs
id love to see a dyno of that gt30 cam I like to know where and what it does to the power.. |
11-20-2018, 08:41 AM | #21 |
Stock LT1 cam- 200 207 .551 .524 116.5
2016 NFG 1SS A8
11-20-2018, 01:47 PM | #22 |
Drives: 2019 ZL-1 Join Date: Feb 2009
I want some chop. The stock cam is a bit lumpy especially cold....
2012 Yukon XL Denali w/ 6.2 AWD |
11-20-2018, 02:26 PM | #23 |
Drives: SS 6 speed of course Join Date: Jan 2016
I was for a long time going do a drop in cam just to show everyone it could be done in a day. The issues I've run into is that given any reasonable spring the DOD lifters are just iffy at best. Literally every DoD cam vendor has something negative to say about the other vendors, for me, outsider, customer only, I don't think it is a cam / shop / grinder issue. It is that DoD lifters are iffy stock and anymore is asking too much IMO of course.
So I went to pull the heads to change to LS7 lifters..... no worries now.
11-20-2018, 03:59 PM | #24 |
Drives: '18 SS 1LE M6 Join Date: Feb 2018
I've heard of more ppl regretting they didn't go bigger vs wishing they went smaller..
I think most get used to the buck of the larger-short lsa-heavy overlap cams. Also any good tuner can tame the car for puttering around town. I have no problems pushing mine through the occasional parking lots & speedbumps I think the lopey exhaust note is the only real consideration you have to make. Just my .02
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
11-20-2018, 05:13 PM | #25 |
with a narrow LSA, one can have a loopy duppy idle and a strong, as in stronger than stock midrange. Keep say 20 degree phaser too, install straight up.
Also the non-DoD cam can for any duration just lift the valves faster / down faster. It would be easy to design say a 212 / 220 114 LSA .600 lift cam the could be completely streetable near stock in pull, but with significant more mid range power and 200 to 400 RPM or so on the top too. There are lots of compromise for DoD that a fast ramp .600 lift street cam does not have to deal with, one is overlap for emissions, two is the ramps for lifting, three is the overall lift.
11-20-2018, 05:24 PM | #26 |
Drives: '17 SS/1LE/PDR Join Date: Feb 2017
We should start a new thread with just cams/vids... post up the cam card or specs. To help potential people on the fence to doing a cam swap. If any, would be a nice change of pace from the endless threads of catback/axleback exhaust sounds connoisseur threads
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
11-20-2018, 05:43 PM | #27 | |
dyno sheets would be even better with that... |
11-20-2018, 05:53 PM | #28 | |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
I agree! If I'm gonna blow my warranty, I may as well do it right. |
